Skip to main content
Netdata MCP
Full-stack observability: the AI SRE that learns your stack!
Metrics · Logs · Traces · Flows · Topology
Infrastructure · APM · NPM · DBM · RUM · Synthetics · Cloud · AI SRE
OpenTelemetry · SNMP · NetFlow/IPFIX/sFlow · IPMI · Redfish · 2,000+ integrations
Netdata is a full-stack observability platform: infrastructure, applications (OpenTelemetry traces), networks, databases, logs and cloud, with 2,000+ integrations. Netdata Agents collect, store and analyze data where it is generated, per second, with machine learning anomaly detection on every metric, and Netdata Parents and Netdata Cloud combine them into one view, from a single node to 100,000+ nodes.
What AI assistants get from Netdata MCP​
Through Netdata MCP, AI assistants query all of Netdata's observability data in real time: metrics, anomalies, alerts, logs, traces, database queries, network topology, flows and traps, and live Functions such as processes and network connections, across every node, from infrastructure and networks to applications. Assistants query the data where it lives, on Netdata Agents and Parents, directly or through Netdata Cloud.
Netdata uses machine learning to model the behavior of the infrastructure and applications. Every metric is scored for anomalies as it is collected, and the scores are stored with the data. Netdata MCP gives assistants the scoring engine behind Netdata's Anomaly Advisor: their context comes from the incident itself, ranked across every metric, not from a random selection of metrics or a playbook:
  • "What was interesting over the last week?" Anomaly rates over time show when clusters of anomalies happened, on which nodes, and how anomalies cascaded across systems, networks and applications.
  • "What was anomalous in this timeframe?" For a window the user gives, Netdata ranks what was anomalous: the blast radius and impact of an incident, and where root cause analysis should start.
  • "What changed the most in this timeframe?" Netdata compares the window with a baseline and ranks the metrics whose behavior changed.
Clusters of anomalies reveal dependencies that would otherwise go unnoticed, show how problems cascade across systems, networks and applications, can identify issues before they become outages, and surface the actual impact of failures. From there, assistants drill down: query any metric, inspect alerts and their history, and explore logs and live processes.
This matters most at scale: across thousands of nodes and millions of metrics, the scoring engine finds the metrics that matter for each incident, wherever they are.
Get started with Netdata · Sign in to Netdata Cloud
Netdata and MCP​
Model Context Protocol (MCP) works in two directions with Netdata:
  • Netdata as an MCP server — AI assistants and clients (Claude, ChatGPT, Cursor, VS Code, CLIs, and more) connect to Netdata to query your full stack: infrastructure, applications, networks, databases, logs and cloud. This page covers server setup; for per-client instructions see Supported AI Clients.
  • Netdata as an MCP client — Netdata Cloud connects out to your own MCP servers (GitHub, PagerDuty, Atlassian, or any custom HTTPS MCP server) so Netdata AI can pull your team's institutional context into troubleshooting. See MCP Connections.
The rest of this page covers Netdata as an MCP server.
Netdata provides MCP servers that enable AI assistants to interact with your observability data. You can connect via:
  • Netdata Cloud — A single cloud-hosted endpoint at https://app.netdata.cloud/api/v1/mcp with full visibility across all your nodes. No bridges, no firewall changes.
  • Local Agent or Parent — Connect directly to any Netdata Agent or Parent (v2.6.0+) on your network at http://YOUR_IP:19999/mcp.
Both options provide comprehensive access to all available observability data through MCP:
  • Node Discovery - Hardware specifications, operating system details, version information, streaming topology, and associated metadata
  • Metrics Discovery - Full-text search capabilities across contexts, instances, dimensions, and labels
  • Function Discovery - Access to system functions including processes, network-connections, streaming, systemd-journal, windows-events, etc.
  • Alert Discovery - Real-time visibility into active and raised alerts
  • Metrics Queries - Complex aggregations and groupings with ML-powered anomaly detection
  • Metrics Scoring - Root cause analysis leveraging anomaly detection and metric correlations
  • Alert History - Complete alert transition logs and state changes
  • Function Execution - Execute Netdata functions on any connected node (requires Netdata Parent)
  • Log Exploration - Access logs from any connected node (requires Netdata Parent)
AI assistants have different visibility depending on where they connect:
ConnectionVisibility
Netdata CloudAll nodes across your entire infrastructure
Netdata ParentAll child nodes connected to that parent
Netdata Child/StandaloneOnly that specific node
FeatureCloud MCPAgent/Parent MCP
ScopeAll nodesSingle agent/parent
Endpointapp.netdata.cloud/api/v1/mcpYOUR_IP:19999/mcp
TransportStreamable HTTPHTTP, SSE, WebSocket
AuthenticationCloud API token (scope:mcp)Local MCP API key (mandatory when bearer protection is enabled)
Network accessInternet onlyDirect access to Netdata IP required
Local setupNoneBridge may be needed for some clients
Netdata Cloud MCP​
Connect AI assistants to your entire Netdata Cloud infrastructure through a single MCP endpoint — no local setup, no bridges, no firewall changes.
Prerequisites​
  1. Netdata Cloud account with a Paid plan
  2. API token with scope:mcp — Create one in API Tokens settings
  3. Nodes claimed to Netdata Cloud — The Cloud MCP server can only access nodes connected to your Netdata Cloud space
Endpoint​
Transport: Streamable HTTP (stateless, works behind load balancers and CDNs)
Authentication​
All requests to the Cloud MCP endpoint require a Bearer token in the Authorization header:
Authorization: Bearer YOUR_NETDATA_CLOUD_API_TOKEN
Creating an API Token​
  1. Log in to Netdata Cloud
  2. Click your profile picture in the bottom-left corner
  3. Select User Settings
  4. Navigate to the API Tokens section
  5. Create a new token with scope:mcp
  6. Copy and store the token securely — you won't be able to see it again
For more details, see API Tokens.
Connection Configuration​
Claude Code (One-Line Setup)​
If you're using Claude Code, you can register the Netdata Cloud MCP server from any session with a single command — no JSON editing required:
claude mcp add --transport http --scope user netdata-cloud \
https://app.netdata.cloud/api/v1/mcp \
--header "Authorization: Bearer YOUR_NETDATA_CLOUD_API_TOKEN"
Replace YOUR_NETDATA_CLOUD_API_TOKEN with a token that has scope:mcp — see Creating an API Token above, or go directly to User Settings → API Tokens in Netdata Cloud.
Scope flags:
  • --scope user — available in all your projects on this machine (recommended for personal use)
  • --scope local — this project only, private to you (default when --scope is omitted)
  • --scope project — this project, checked into .mcp.json and shared with your team (do not use with a raw token; reference an environment variable instead)
Useful companion commands:
claude mcp list # show all configured servers and their connection status
claude mcp get netdata-cloud # show the configuration for this server
claude mcp remove netdata-cloud -s user # remove the server (match the scope you added with)
Restart the Claude Code session after adding the server so the new tools load.
For more Claude Code options — including connecting to a local Netdata Agent or Parent — see the Claude Code guide.
Generic MCP Client (HTTP Transport)​
For any MCP client that supports Streamable HTTP transport:
"mcpServers": {
"netdata-cloud": {
"type": "http",
"url": "https://app.netdata.cloud/api/v1/mcp",
"headers": {
"Authorization": "Bearer YOUR_NETDATA_CLOUD_API_TOKEN"
Clients Requiring stdio Bridge​
For MCP clients that only support stdio transport, use npx mcp-remote as a bridge:
"mcpServers": {
"netdata-cloud": {
"command": "npx",
"args": [
"mcp-remote@latest",
"--header",
Replace YOUR_NETDATA_CLOUD_API_TOKEN with your API token (must have scope:mcp).
Cloud MCP Troubleshooting​
Authentication Errors​
  • Verify your API token has scope:mcp
  • Ensure the token is passed as Authorization: Bearer <token> (not as a query parameter)
  • Check that your Netdata Cloud subscription includes a space in a Paid plan
No Nodes Visible​
  • Confirm your nodes are claimed to Netdata Cloud and appear in the web dashboard
  • Check that agents are online and streaming to Cloud
Connection Issues​
  • The endpoint uses HTTPS — no --allow-http flag is needed
  • Test connectivity: curl -H "Authorization: Bearer YOUR_TOKEN" https://app.netdata.cloud/api/v1/mcp
Local Agent or Parent MCP​
Connect directly to any Netdata Agent or Parent on your network. All Netdata Agents and Parents (v2.6.0+) include a built-in MCP server at http://YOUR_IP:19999/mcp.
Netdata generates a local MCP API key automatically on startup. Authentication behavior depends on [web].bearer token protection:
  • Bearer protection disabled (no): anonymous MCP access works for non-sensitive operations (metrics, alerts, node info). The API key unlocks sensitive operations.
  • Bearer protection enabled (yes): anonymous MCP access is rejected on all MCP transports (HTTP, SSE, WebSocket). The API key is required for all MCP requests.
  • Claiming required: the Agent accepts the API key only while it is claimed to Netdata Cloud. On an unclaimed Agent every key is rejected, so with bearer protection enabled MCP is unavailable.
  • MCP only: the API key does not authorize the Agent's REST API (/api/...). With bearer protection enabled, those endpoints still require a Cloud-issued bearer token.
Transport Options​
Netdata implements the MCP protocol with multiple transport options:
TransportEndpointUse CaseVersion Requirement
WebSocketws://YOUR_IP:19999/mcpOriginal transport, requires nd-mcp bridge for stdio clientsv2.6.0+
HTTP Streamablehttp://YOUR_IP:19999/mcpDirect connection from AI clients supporting HTTPv2.7.2+
SSEhttp://YOUR_IP:19999/sseServer-Sent Events for real-time streamingv2.7.2+
  • Direct Connection (v2.7.2+): AI clients that support HTTP or SSE transports can connect directly to Netdata
  • Bridge Required: AI clients that only support stdio need the nd-mcp (stdio-to-websocket) or mcp-remote (stdio-to-http or stdio-to-sse) bridge
  • Preferred authentication: pass the MCP API key via Authorization: Bearer <mcp_key>.
  • Backward compatibility: WebSocket also accepts ?api_key=<mcp_key>. Keep this only for legacy clients, since URL query strings are more likely to be logged by proxies and tools.
  • Request limits: an HTTP or SSE request body can be about 1 MiB, and a WebSocket message up to 1 MiB (a larger one closes the connection with code 1009). A JSON-RPC batch can hold up to 64 requests. Once its responses reach 16 MiB, the remaining requests are not run: each valid request with an id gets a -32001 error, and a response that would cross the limit is replaced by that error too.
MCP Access Control in netdata.conf​
Use a dedicated MCP ACL to control network-level MCP access independently from dashboard and streaming:
[web]
allow connections from = 10.* 192.168.* localhost
allow dashboard from = 10.* 192.168.* localhost
allow mcp from = 10.* 192.168.* localhost
allow streaming from = *
allow mcp by dns = heuristic
  • allow mcp from controls /mcp, /sse, and MCP WebSocket protocol access.
  • allow connections from is still the global first gate for all features.
  • For internet-facing Parents, keep allow mcp from restricted to trusted networks.
Official MCP Remote Client (mcp-remote)​
If your AI client doesn't support HTTP/SSE directly and you don't want to use nd-mcp, you can use the official MCP remote client (requires Netdata v2.7.2+):
# Export your MCP key once per shell
export NETDATA_MCP_API_KEY="$(cat /var/lib/netdata/mcp_dev_preview_api_key)"
# For HTTP transport
npx mcp-remote@latest --http http://YOUR_NETDATA_IP:19999/mcp \
--allow-http \
--header "Authorization: Bearer $NETDATA_MCP_API_KEY"
# For SSE transport
npx mcp-remote@latest --sse http://YOUR_NETDATA_IP:19999/mcp \
--allow-http \
Note: The --allow-http flag is required for non-HTTPS connections. Only use this on trusted networks as traffic will not be encrypted.
Finding the nd-mcp Bridge​
Note: With the new HTTP and SSE transports, many AI clients can now connect directly to Netdata without nd-mcp. Check your AI client's documentation to see if it supports direct HTTP or SSE connections.
The nd-mcp bridge is only needed for AI clients that:
  • Only support stdio communication (like some desktop applications)
  • Cannot use HTTP or SSE transports directly
  • Cannot use npx mcp-remote@latest
The nd-mcp bridge needs to be available on your desktop or laptop where your AI client runs. Since most users run Netdata on remote servers rather than their local machines, you have two options:
  1. If you have Netdata installed locally - Use the existing nd-mcp
  2. If Netdata is only on remote servers - Build nd-mcp on your desktop/laptop
Option 1: Using Existing nd-mcp​
If you have Netdata installed on your desktop/laptop, find the existing bridge:
Linux​
# Try these locations in order:
which nd-mcp
ls -la /usr/sbin/nd-mcp
ls -la /usr/bin/nd-mcp
ls -la /opt/netdata/usr/bin/nd-mcp
ls -la /usr/local/bin/nd-mcp
ls -la /usr/local/netdata/usr/bin/nd-mcp
# Or search for it:
find / -name "nd-mcp" 2>/dev/null
Common locations:
  • Native packages (apt, yum, etc.): /usr/sbin/nd-mcp or /usr/bin/nd-mcp
  • Static installations: /opt/netdata/usr/bin/nd-mcp
  • Built from source: /usr/local/netdata/usr/bin/nd-mcp
macOS​
# Try these locations:
which nd-mcp
ls -la /opt/homebrew/bin/nd-mcp
# Or search for it:
Windows​
# Check common locations:
dir "C:\Program Files\Netdata\usr\bin\nd-mcp.exe"
dir "C:\Netdata\usr\bin\nd-mcp.exe"
# Or search for it:
where nd-mcp.exe
Option 2: Building nd-mcp for Your Desktop​
If you don't have Netdata installed locally you can build just the nd-mcp bridge. Netdata provides three implementations - choose the one that best fits your environment:
  1. Go bridge (recommended) - Go bridge source code
    • Produces a single binary with no dependencies
    • Creates executable named nd-mcp (nd-mcp.exe on windows)
    • Includes both build.sh and build.bat (for Windows)
  2. Node.js bridge - Node.js bridge source code
    • Good if you already have Node.js installed
    • Creates script named nd-mcp.js
    • Includes build.sh
  3. Python bridge - Python bridge source code
    • Good if you already have Python installed
    • Creates script named nd-mcp.py
    • Includes build.sh
To build:
# Clone the Netdata repository
git clone https://github.com/netdata/netdata.git
cd netdata
# Choose your preferred implementation
cd src/web/mcp/bridges/stdio-golang/ # or stdio-nodejs/ or stdio-python/
# Build the bridge
./build.sh # On Windows with the Go version, use build.bat
# The executable will be created with different names:
# - Go: nd-mcp
# - Node.js: nd-mcp.js
# - Python: nd-mcp.py
# Test the bridge with your Netdata instance (replace localhost with your Netdata IP)
./nd-mcp ws://localhost:19999/mcp # Go bridge
./nd-mcp.js ws://localhost:19999/mcp # Node.js bridge
./nd-mcp.py ws://localhost:19999/mcp # Python bridge
# You should see:
# nd-mcp: Connecting to ws://localhost:19999/mcp...
# nd-mcp: Connected
# Press Ctrl+C to stop the test
# Get the absolute path for your AI client configuration
pwd # Shows current directory
# Example output: /home/user/netdata/src/web/mcp/bridges/stdio-golang
# Your nd-mcp path would be: /home/user/netdata/src/web/mcp/bridges/stdio-golang/nd-mcp
Important: When configuring your AI client, use the full absolute path to the executable:
  • Go bridge: /path/to/bridges/stdio-golang/nd-mcp
  • Node.js bridge: /path/to/bridges/stdio-nodejs/nd-mcp.js
  • Python bridge: /path/to/bridges/stdio-python/nd-mcp.py
Verify the Bridge Works​
Once you have nd-mcp (either from existing installation or built), test it:
# Test connection to your Netdata instance (replace YOUR_NETDATA_IP with actual IP)
/path/to/nd-mcp ws://YOUR_NETDATA_IP:19999/mcp
# You should see:
# nd-mcp: Connecting to ws://YOUR_NETDATA_IP:19999/mcp...
# nd-mcp: Connected
Using MCP Remote Client​
The official MCP remote client (mcp-remote) is an alternative bridge that enables stdio-only AI clients to connect to Netdata's HTTP and SSE transports (requires Netdata v2.7.2+). Unlike nd-mcp which only supports WebSocket, mcp-remote provides broader transport compatibility.
When to Use MCP Remote​
Use mcp-remote when:
  • Your AI client only supports stdio communication
  • You want to use HTTP or SSE transports instead of WebSocket
  • You're running Netdata v2.7.2 or later
  • You don't want to build/install nd-mcp
Installation​
No installation required - mcp-remote runs via npx:
# Test the connection
--allow-http \
--header "Authorization: Bearer YOUR_API_KEY"
Transport Options​
mcp-remote supports multiple transport strategies:
# HTTP transport (recommended)
--allow-http \
# SSE transport
--allow-http \
# Auto-detect with fallback (tries SSE first, falls back to HTTP)
npx mcp-remote@latest --transport sse-first http://YOUR_NETDATA_IP:19999/mcp \
--allow-http \
# HTTPS (no --allow-http flag needed)
npx mcp-remote@latest --http https://YOUR_NETDATA_IP:19999/mcp \
Common Options​
OptionDescriptionExample
--httpUse HTTP transport--http http://host:19999/mcp
--sseUse SSE transport--sse http://host:19999/mcp
--allow-httpAllow non-HTTPS connections (required for HTTP URLs)--allow-http
--headerAdd custom headers (for authentication)--header "Authorization: Bearer KEY"
--transportTransport strategy--transport sse-first (tries SSE, falls back to HTTP)
--debugEnable debug logging--debug
--hostOAuth callback host (default: localhost)--host 127.0.0.1
Port numberOAuth callback port (optional)9696
Authentication​
For Netdata MCP, pass the API key via the Authorization header:
# Using environment variable (recommended)
--allow-http \
Security Note: The --allow-http flag is required for non-HTTPS connections. Only use this on trusted networks as traffic will not be encrypted.
Troubleshooting​
Connection Issues:
# Enable debug logging
npx mcp-remote@latest --debug --http http://YOUR_NETDATA_IP:19999/mcp \
--allow-http \
# Check debug logs (stored in ~/.mcp-auth/)
cat ~/.mcp-auth/*_debug.log
Clear Authentication State:
# Remove cached credentials
rm -rf ~/.mcp-auth
Spaces in Arguments:
Some AI clients (Cursor, Claude Desktop on Windows) have issues with spaces in arguments. Use environment variables as a workaround:
"mcpServers": {
"netdata": {
"command": "npx",
"args": [
"--http",
"http://YOUR_IP:19999/mcp",
"--allow-http",
"--header",
Version Management​
Always use the latest version:
# Force npx to check for latest version
Or in AI client configurations:
"args": ["mcp-remote@latest", "--http", "..."]
For more details, see the official mcp-remote documentation.
Finding Your API Key​
You need the MCP API key when bearer protection is enabled. When bearer protection is disabled, the key is still needed for sensitive functions like logs and live system information. Netdata automatically generates an API key on startup. The key is stored in a file on the Netdata server you want to connect to.
You need the API key of the Netdata you will connect to (usually a Netdata Parent).
Note: This temporary API key mechanism will eventually be replaced by integration with Netdata Cloud.
Find the API Key File​
# Try the default location first:
sudo cat /var/lib/netdata/mcp_dev_preview_api_key
# For static installations:
sudo cat /opt/netdata/var/lib/netdata/mcp_dev_preview_api_key
# If not found, search for it:
sudo find / -name "mcp_dev_preview_api_key" 2>/dev/null
Copy the API Key​
The file contains a UUID that looks like:
a1b2c3d4-e5f6-7890-abcd-ef1234567890
Copy this entire string - you'll need it for your AI client configuration.
No API Key File?​
If the file doesn't exist:
  1. Ensure you have a recent version of Netdata
  2. Restart Netdata: sudo systemctl restart netdata
  3. Check the file again after restart
AI Client Configuration​
AI clients can connect to Netdata MCP in different ways depending on their transport support:
Direct Connection (HTTP/SSE)​
For AI clients that support HTTP or SSE transports:
"mcpServers": {
"netdata": {
"type": "http",
"url": "http://IP_OF_YOUR_NETDATA:19999/mcp",
"headers": [
Or for SSE:
"mcpServers": {
"netdata": {
"type": "sse",
"url": "http://IP_OF_YOUR_NETDATA:19999/mcp?transport=sse",
"headers": [
Using nd-mcp Bridge (stdio)​
For AI clients that only support stdio:
"mcpServers": {
"netdata": {
"command": "/usr/sbin/nd-mcp",
"args": [
"--bearer",
"YOUR_API_KEY",
"ws://IP_OF_YOUR_NETDATA:19999/mcp"
Using Official MCP Remote Client​
"mcpServers": {
"netdata": {
"command": "npx",
"args": [
"--http",
"--header",
Replace:
  • IP_OF_YOUR_NETDATA: Your Netdata instance IP/hostname
  • YOUR_API_KEY: The API key from the file mentioned above
  • /usr/sbin/nd-mcp: With your actual nd-mcp path (if using the bridge)
Multiple MCP Servers​
You can configure multiple Netdata instances:
"mcpServers": {
"netdata-production": {
"args": ["--bearer", "PROD_KEY", "ws://prod-parent:19999/mcp"]
"netdata-testing": {
"args": ["--bearer", "TEST_KEY", "ws://test-parent:19999/mcp"]
Legacy Query String Support​
For compatibility with older tooling, Netdata still accepts the ?api_key=YOUR_API_KEY query parameter on the /mcp endpoints. New integrations should prefer the Authorization: Bearer YOUR_API_KEY header, but the query-string form remains available if you are migrating gradually.
AI Client Specific Documentation​
For detailed configuration instructions for specific AI clients, see:
Chat Clients:
DevOps Copilots:
Each guide includes specific transport support matrices and configuration examples optimized for that client.
