Metric relabeling
pkg/relabel provides the shared Prometheus-compatible rule processor and ordered block pipeline.
They transform a Record containing only Name and Labels; values and metric types remain with the caller.
__name__ is a virtual label backed by Name and MUST NOT also appear in Labels.
New compiles rules into a Processor; NewPipeline compiles name-matched blocks. Both own reusable scratch and
MUST be used serially. Applying rules does not mutate the input label set. A dropped processor result returns the
record at processor entry; a dropped pipeline result returns the record at entry to the dropping block, preserving
changes from earlier successful blocks. Callers MUST discard dropped results and may use the returned record for
diagnostics. Observer callbacks run synchronously and MUST NOT re-enter the same processor or pipeline.
The shared package does not assemble metric families, select profiles, or validate collector-specific values or labels. The following configuration guide describes its integration in the Prometheus collector, which owns the stage order and histogram/summary protection.
Prometheus collector integration
Relabeling rewrites, adds, drops, or filters a scraped metric -- its name and its labels -- before charts are built.
The same relabeling block format has two configuration levels:
- Job relabeling is operator policy. It runs after the job's
selectorand before chart profiles are selected, so it can bring an endpoint into a profile's expected namespace. - Profile relabeling is exporter/profile policy. It is stored at the profile root, applies automatically only after that profile is selected, and normalizes the metrics its template sees. It cannot cause its own selection.
Both levels use the same validation and execution path. The rule shape is Prometheus-compatible: it mirrors
Prometheus
metric_relabel_configs,
so rules you already use in Prometheus carry over -- with these deliberate exceptions: the __name__ handling of the
label-name actions (see Actions), and the histogram/summary integrity protection, which rejects rules --
such as thinning buckets by le -- that Prometheus allows (see
Histogram and summary safety). When porting, wrap your flat metric_relabel_configs
list in a relabeling block with a required match (use '*' for all metrics). The job's selector option runs
first, on the original scraped names -- neither relabeling stage can recover a series the selector dropped.
Use job relabeling to keep noisy metrics out of your dashboards, fold high-cardinality labels away, derive deployment labels, or rename an endpoint so a profile recognizes it. Put stable exporter normalization required by a curated profile in the profile itself, so every job that selects that profile gets the same metric contract without duplicating an optional job policy.
Note: The removed
label_prefixoption prefixed every label key. Relabeling covers its practical use case -- avoiding collisions with the labels Netdata adds when re-exporting -- with a targetedlabelmaprule (see the example). A blanket all-labels rename has no direct equivalent:labelmapcopies labels, it does not rename them.
How a rule reads
Relabeling operates per scraped series (one sample line of the exposition), not per metric family. Each rule transforms one series in a few steps:
- Join the values of the metric's
source_labels(withseparator) into one input string. The metric's own name is available as a special label,__name__. - Match that input against
regex. Theregexis a regular expression that must match the whole input, not a substring (wrap it in.*to match a part). - Act: the
actiondecides what happens -- set or rename a label, drop or keep the metric, and so on. If you omitaction, it defaults toreplace. - Write --
replacewrites the expandedreplacement(withregexcapture groups:$1, or${name}) intotarget_label; use__name__to rename the metric.lowercase/uppercase/hashmodalso writetarget_label, but withoutreplacementexpansion. The keep/drop actions write nothing, and the label-name actions operate on label names directly, never ontarget_label. Alabelmapreplacement that expands to__name__is the exception: it copies the matching application label's value into the metric name -- see Actions.
Two different matchers are at play -- don't confuse them: a block's match is a glob (simple pattern) over the
metric name, while a rule's regex is an anchored regular expression over the joined label values.
Quick start
Add a relabeling block to a job. This drops the go_gc_duration_seconds metric and derives an HTTP code_class label
(2xx, 4xx, ...) on every http_* metric:
jobs:
- name: myapp
url: http://127.0.0.1:9090/metrics
relabeling:
- match: 'go_gc_duration_seconds*'
metric_relabel_configs:
- action: drop
- match: 'http_*'
- source_labels: [code]
regex: '(\d)\d\d'
target_label: code_class
replacement: '${1}xx'
The drop and label-deriving techniques are explained step by step under Relabeling examples.
Configuration
relabeling is a list of blocks. Each block has a match and a list of rules; the rules apply only to metrics
whose name matches the block's match. Grouping rules under a block lets you scope a set of rules to a subset of
metrics by name, instead of repeating a name match in every rule. Relabeling is opt-in at both levels -- a
job or profile without a relabeling section adds no rules at that stage.
jobs:
- name: myapp
relabeling:
- match: '<simple-pattern>' # REQUIRED
- source_labels: [<label>, ...]
separator: ';'
regex: '<regexp>'
modulus: <uint>
target_label: '<label>' # or __name__ to target the metric name
replacement: '$1'
action: <action>
The same field may appear at the root of a profile. The profile's root match controls selection and source-family
applicability; the relabeling block match controls which physical series names its rules process:
match: 'myapp_*'
relabeling:
- match: 'myapp_legacy_*'
- source_labels: [__name__]
regex: 'myapp_legacy_(.+)'
target_label: __name__
replacement: 'myapp_${1}'
template:
match
match selects which metrics a block's rules apply to. It is required.
- Syntax is a Netdata simple pattern: a space-separated list of globs where
*matches any sequence,?matches any single character, and a leading!negates a term. - It is matched against the full metric name, including the
_bucket/_sum/_countsuffixes of histograms and summaries. Prefer a glob likeapp_lat*over an exactapp_lat, otherwise the histogram's_bucket/_sum/_countseries will not match. (Profilematchworks on family base names instead.) - Use
*to target every metric.
Blocks run in order, and match sees each metric's current name -- so a block can match the new name produced by an
earlier block's rename.
Rule fields
Inside a block, metric_relabel_configs is a list of rules applied in order (see
How a rule reads). Every field is optional except where an action requires it; action defaults to
replace.
| Field | Description | Default |
source_labels | Label names whose values are joined (with separator) into the rule's input string. Use __name__ for the metric name. | -- |
separator | String placed between joined source_labels values. | ; |
regex | Regular expression matched against the joined input. It is fully anchored (compiled as ^(?s:...)$, so it must match the whole input and . also matches newlines); to match a substring, wrap it in .*. | (.*) |
modulus | Positive integer, used only by the hashmod action. | -- |
target_label | The label the action writes. Use __name__ to write the metric name. For replace, it also expands regex capture groups ($1, ${name}), like replacement. | -- |
replacement | The value written, with regex capture-group expansion ($1, or ${name} for named groups). | $1 |
action | One of the actions below. | replace |
Actions
| Action | What it does |
replace | If regex matches the joined input, set target_label to the expanded replacement (an empty result removes the label); a non-match leaves the label unchanged. With no source_labels, the default regex matches the empty input, so replace writes a constant replacement -- the standard add-a-static-label idiom. See example. |
keep | Keep the series only if regex matches the joined input; otherwise drop it. See example. |
drop | Drop the series if regex matches the joined input. See example. |
keepequal | Keep the series only if target_label's value equals the joined input. Accepts only source_labels and target_label. |
dropequal | Drop the series if target_label's value equals the joined input. Accepts only source_labels and target_label. |
hashmod | Set target_label to md5(joined input) mod modulus (Prometheus-compatible hashing) -- useful for sharding. |
labelmap | For every label whose name matches regex, copy its value to a new label whose name is replacement with capture groups from the label name expanded (e.g. app_$1). See example. |
labeldrop | Remove every label whose name matches regex. See example. |
labelkeep | Remove every label whose name does not match regex. See example. |
lowercase | Set target_label to the lowercased joined input. See example. |
uppercase | Set target_label to the uppercased joined input. See example. |
Differs from Prometheus. The label-name actions never process the metric name (
__name__) as an input label. A portedlabelkeepwhose regex omits__name__, a blanketlabeldrop, or alabelmapover the metric name therefore leaves the metric name untouched in Netdata. However,labelmapignoressource_labelsand can still write the metric name when its replacement expands to__name__; the new name is the value of the matching application label. Prefer an explicitreplacerule withsource_labels: [__name__]andtarget_label: __name__for deliberate metric renaming.
How relabeling runs
The Prometheus collector fixes the stage order:
- The job
selectorfilters original scraped series. - Job relabeling runs and its result is assembled and checked.
- Untyped fallback classification and profile selection use the post-job, pre-profile names.
- Selected profile relabeling runs and its result is assembled and checked independently.
- Final size/writer checks run, then charts see the normalized result.
Inside either relabeling stage:
- For each metric, every block whose
matchmatches the metric's current name runs, in order. - Within a block, rules run in order. Each rule joins
source_labelsinto an input string and applies itsaction. - A rule can rename the metric (write
__name__), so a later block or rule sees the new name. - If any rule drops the metric, the remaining rules and blocks are skipped for it.
In the Prometheus collector, a histogram or summary is assembled from several series -- _bucket/_sum/_count, or per-quantile series. Netdata
will not let relabeling silently corrupt one. A rule that would:
- split a histogram/summary across multiple metric names,
- drop only some of its components,
- change its
leorquantilelabel, - merge two metric families together, or
- duplicate a component,
is rejected independently at each stage. The job fails at autodetection, so a bad rule is caught immediately; if the exposition changes at runtime, the affected metric family is dropped (rather than charted with wrong values) and the rest of the job keeps working. A later profile stage cannot hide corruption introduced by the job stage.
This also covers the common Prometheus technique of thinning histogram buckets: a keep/drop rule on the le (or
quantile) label is treated as corrupting the metric family, never as thinning it -- the job fails its check when the
check scrape shows the family partially dropped or mutated, and the whole metric family is dropped if the exposition
drifts into corruption later at runtime. Reduce histogram cardinality at the exporter or with the job's selector
option instead.
Plain gauges and counters have no such restriction -- you can rename, relabel, split, or drop them freely.
Profile precedence on the shared stream
Selected profiles share one final metric stream; the collector does not copy source metrics per profile. For each
original source family, it chooses the first selected profile whose root match covers the base family and whose
relabeling block matcher covers at least one original physical series. That profile's complete pipeline receives every
series in the family. Later profile pipelines do not process the family and do not see names produced by the first one.
Normalizer precedence is profile-name order in auto, configured entry order in exact, and configured entries first
followed by the remaining auto-selected profiles in profile-name order in combined. Block and rule order inside the
chosen profile remains the YAML order described above.
Dispatch does not predict rule results or output names. The root match constrains the original source family only, and
the chosen pipeline may produce a different namespace. Every selected chart template sees those final names and labels,
so profile authors must account for interactions between profiles selected for the same endpoint. See the profile
format's relabeling section for authoring
guidance. A family renamed outside the profile's root match also leaves that profile's autogen.selector scope, so an
uncovered output keeps generic autogen unless another applicable profile scope rejects it.
Untyped fallback type is bound from the post-job, pre-profile name using declared, job, selected-profile, and implicit
_total precedence. Profile relabeling preserves that decision but cannot create one by adding _total or renaming a
final metric into a job/profile fallback_type pattern. See the profile format's
fallback_type section for the full order.
Examples
Drop metrics you don't want
Drop everything named go_*:
relabeling:
- match: 'go_*'
- action: drop
match: 'go_*' already selects the metrics, so the rule needs no regex -- it drops every metric the block sees.
Keep only specific metrics
Within a metric family, drop everything except a chosen series by matching a label. This keeps only
node_systemd_unit_state samples whose state is active, dropping the rest:
relabeling:
- match: 'node_systemd_unit_state'
- source_labels: [state]
regex: 'active'
action: keep
keep drops any sample whose state label is not exactly active (the regex is fully anchored).
Add a derived label
Derive an HTTP code_class (2xx, 4xx, ...) from a numeric code label:
relabeling:
- match: 'http_*'
regex: '(\d)\d\d'
For code="404", the rule writes code_class="4xx". The original code label is left untouched.
Rename a metric
Write __name__ to rename the metric itself:
relabeling:
- match: 'legacy_app_requests_total'
regex: 'legacy_(.*)'
replacement: '$1'
legacy_app_requests_total becomes app_requests_total. (Renaming a histogram/summary is allowed only when all of its
components are renamed together -- see Histogram and summary safety.)
Remove a high-cardinality label
Drop a label that explodes cardinality and clutters charts:
relabeling:
- match: '*'
- regex: 'pod_uid'
action: labeldrop
Every pod_uid label is removed from all metrics. To drop several, use an alternation like
regex: 'pod_uid|instance_id'.
Keep only a few labels
Strip a metric down to a known set of labels, removing everything else:
relabeling:
- match: 'mysql_*'
- regex: 'instance|job'
action: labelkeep
labelkeep removes every label whose name is not in the regex. The metric name (__name__) is always kept, so you
do not list it.
Normalize label case
Lowercase a label value so GET, Get, and get collapse into one dimension:
relabeling:
- match: 'http_*'
- source_labels: [method]
target_label: method
action: lowercase
Use uppercase for the opposite. These actions take source_labels, separator, and target_label (the target is
often the same label).
Prefix label names (replaces label_prefix)
When these metrics are re-exported in Prometheus format, Netdata adds its own instance, family, chart, and
dimension labels. If the scraped endpoint already uses one of those names, the re-export emits a duplicate label and a
downstream Prometheus rejects the scrape. Rename the colliding labels -- copy them to a prefixed name with labelmap,
then drop the originals with labeldrop:
relabeling:
- match: '*'
- regex: '(instance|family)'
action: labelmap
replacement: 'app_$1'
action: labeldrop
labelmap copies instance -> app_instance and family -> app_family (the ( ) capture feeds $1 in
replacement); the labeldrop then removes the originals -- its anchored regex matches those names exactly, not the
new app_ ones. Add more names to the alternation for other collisions; __name__ is never affected. The removed
label_prefix option prefixed every label key; the re-export collision shown here is the problem it existed to solve.
Prefix only the labels that actually collide -- a generic all-labels rename is not expressible with these actions,
because labelmap copies labels and the originals cannot be dropped without naming them.
Scope rules to a subset of metrics
Each block's match already scopes its rules. Combine blocks to apply different rules to different metric sets:
relabeling:
- match: 'http_*'
- regex: 'pod_uid'
action: labeldrop
- match: 'db_* cache_*'
- source_labels: [shard]
target_label: shard
action: uppercase
The first block touches only http_* metrics; the second touches db_* and cache_*. A metric matched by no block is
left unchanged.
