Skip to main content
Deploy and Identify Fleet Devices
Give every device a place in your fleet's monitoring view. Install a small Netdata Agent in your device image, connect it to a Parent, and attach the labels your team uses to organize customers, sites and releases. The Parent brings the devices' charts, alerts and live troubleshooting into one interface.
Prepare a package for each device class​
Netdata provides static Linux packages for 32-bit ARM devices, including armv6l and armv7l. Choose the package for your device's CPU and operating system, then use the disk-footprint guide to retain the capabilities your team needs.
For example, monitor a signage player's system and processes; include hardware sensors, container monitoring and application telemetry for a robot running containerized control software. Use the same package and runtime configuration across devices with the same role.
Preserve each device's identity​
Generate the Agent identity on first boot and preserve it through image updates. Each device then appears as its own node, with monitoring history that follows it across releases.
Prepare shared images before claiming or commissioning their Agents. The VM template guide explains which identity and Cloud credentials to initialize separately on each device.
Attach customer and location labels​
Add a [host labels] section to the device's netdata.conf:
[host labels]
customer = tenant-a
location = north-campus
building = warehouse-2
room = loading-bay
model = robot-r2
software-version = 2026.10.1
deployment-ring = pilot
Populate these values through your provisioning system. The labels travel with the device's metrics, so operators can filter and group by customer, site, room, hardware or software release. Use a stable hostname to make individual devices easy to recognize.
The label configuration guide also shows how to populate labels from environment variables. The fleet monitoring guide shows how to use them in maps and investigations.
Connect devices to a Parent​
Start with this configuration on a private network. In the Child's stream.conf:
[stream]
enabled = yes
destination = parent.example:19999
api key = YOUR_STREAMING_API_KEY
enable compression = yes
In the Parent's stream.conf:
[YOUR_STREAMING_API_KEY]
enabled = yes
allow from = YOUR_DEVICE_NETWORK
db = dbengine
health enabled = yes
tcp keepalive idle = auto
The Parent uses automatic TCP keepalives by default. The explicit auto line above documents that default; you can omit it. It adapts keepalive frequency to the fastest streamed chart interval, as explained in the cellular guide.
Use the same UUID for YOUR_STREAMING_API_KEY on both sides. Replace YOUR_DEVICE_NETWORK with the permitted source addresses or network pattern. A shared streaming key can authorize a device group while each device keeps its own identity and history. Per-device authorization is available when you need finer control.
Enable centralized alerting and anomaly detection in the Parent's netdata.conf:
[health]
enabled = yes
[ml]
enabled = yes
Apply the lightweight Child configuration on the devices. The Children collect; the Parent stores history, evaluates alerts and runs machine learning.
Keep health enabled on Children that need autonomous responses. Their local alerts can trigger custom device actions while the Parent continues central alerting and notifications.
Secure the connection and operator access​
For cellular or other untrusted networks, provision the Parent's server certificate and private key, and make them readable by its Agent. Set their paths in the Parent's netdata.conf:
[web]
ssl key = /etc/fleet/parent-key.pem
ssl certificate = /etc/fleet/parent-cert.pem
Provision the trusted CA certificate on each device and add these settings to the Child's [stream] section:
destination = parent.example:19999:SSL
ssl skip certificate verification = no
CAfile = /etc/fleet/parent-ca.pem
Place the trusted CA certificate at the configured path. Allow outbound access to the Parent's streaming port, directly or through your fleet VPN. See TLS certificate configuration for Parent certificates and the Parent-Child reference for destination syntax and authorization.
Claim the Parent to your Netdata Cloud Space to give your team a central operating view. Manage customer access through Cloud permissions and Rooms, and give authorized signed-in operators live Functions such as process inspection. Streaming keys authorize device connections; Cloud permissions authorize your operators.
Roll out the device image​
Start with a pilot group. Open the Parent dashboard to see the devices, labels and incoming charts, and run the live Functions your team will use. Enable the Parent's alerts and anomaly detection, then deploy the same image and configuration to the rest of the device class.
Use the update guide to keep each device's identity, reduced package and monitoring policy together through future releases.
