Netdata Streaming Routing
Streaming routing controls how Netdata child nodes connect to parent nodes when multiple parents are available. It handles three key operations: initial parent selection, connection management, and failover.
This feature requires configuring streaming in netdata.conf. See Streaming Configuration for setup instructions.
How Streaming Routing Works
1. Initial Parent Selection
When a child node starts, it queries all configured parents simultaneously to determine the best connection:
How it works:
- Child sends HTTP requests to all parents in parallel
- Each parent responds with:
- Last timestamp of this child's data (if any)
- Random seed for load balancing
- Child calculates time delta for each parent
- Selection based on data recency (not data amount)
Example:
# In child's stream.conf
[stream]
enabled = yes
destination = parent-a:19999 parent-b:19999 parent-c:19999
api key = YOUR_API_KEY
With this configuration:
Child Node startup:
├─→ Parent A (has historical data) ✓ Selected (random between A & B)
├─→ Parent B (has historical data)
└─→ Parent C (no historical data) ← Lower priority
2. Connection Management
Once connected, the child maintains a persistent connection:
- Connection timeout: 60 seconds (default)
- Keepalive: Continuous streaming maintains connection
- No automatic rebalancing: Child stays connected until failure
- Data integrity: Historical metrics are replicated automatically after reconnection
Netdata automatically replicates missing historical data when reconnection occurs. Data is only lost if:
- Child restarts during disconnection AND
- Child uses
[db].db = ram(metrics stored in memory) AND - Disconnection exceeds retention period (default: 1 hour for RAM mode)
For persistent data, use [db].db = dbengine.
Children do not automatically reconnect to their original parent after failover. This prevents connection flapping but requires manual intervention for load redistribution.
3. Failover and Reconnection
When the active connection fails, the child repeats the parent selection process:
Unlike traditional round-robin failover, Netdata re-evaluates all parents on each attempt. This means a child might connect to a different parent than expected if data states have changed.
Failover Example:
Normal: Child → Parent A
Failure: Child ✗ Parent A (connection lost)
Child → Parent B (immediate failover)
Recovery: Parent A comes back online
Child → Parent B (stays connected - no automatic switch)
Key Routing Behaviors
| Behavior | Description | Impact |
| Data Recency Priority | Selects parent with most recent data (lowest time delta) | Minimizes gap in historical data |
| Parallel Parent Query | Queries all parents simultaneously via HTTP | Fast parent selection, no sequential delays |
| Sticky Connections | No automatic rebalancing after failover | Requires manual intervention to redistribute load |
| Smart Failover | Re-evaluates all parents on each connection attempt | May connect to different parent based on current data state |
| Connection Persistence | Maintains connection until failure occurs | Prevents unnecessary reconnections and data gaps |
| No Health Checks | Doesn't proactively test parent availability | Discovers failures only when connection breaks |
| Randomized Delays | Reconnection waits random time (5s to configured maximum) | Prevents thundering herd during mass reconnections |
Configuration Reference
Essential Parameters
[stream]
# Streaming targets (space-separated list)
# Order doesn't matter - selection is based on data recency
destination = parent1:19999 parent2:19999 parent3:19999
# Reconnection delay - randomized between 5 and this value (seconds)
# Default: 5, Minimum: 5
reconnect delay seconds = 5
# Initial connection timeout
timeout seconds = 60
Multi-Tier Setup
For larger deployments:
Child Nodes ──→ Parent Proxies ──→ Ultimate Parents
(forward only) (store & analyze)
Configure intermediate parents as proxies to distribute load without storage overhead.
Monitoring Streaming Status
Check Connection Status
Using the UI
The Netdata Streaming function (under the "Functions" tab) provides:
- Comprehensive overview of all streaming connections
- Status, replication completion time, and connection details
- Works on both parent and child nodes:
- On child: Shows outgoing connections
- On parent: Shows incoming connections (InHops = 1 for direct children, >1 for proxied connections)
Viewing Logs
# Check journal for streaming-related messages
journalctl _SYSTEMD_INVOCATION_ID="$(systemctl show --value --property=InvocationID netdata)" --namespace=netdata --grep stream
Verify Parent Connectivity
# Test each parent
nc -zv parent-a 19999
nc -zv parent-b 19999
If a child connects to an unexpected parent, check the data retention on all parents. The child prefers parents that already have its historical data.
Common Scenarios
| Scenario | What Happens | Why |
| Parent A fails | Child switches to Parent B | Automatic failover |
| All parents fail | Child cycles through list every second | Continuous retry |
| Parent A recovers | Child stays on Parent B | No automatic rebalancing |
| New child starts | Randomly selects from parents with data | Load distribution |
When taking a parent offline for maintenance, its children will fail over to other parents and won't automatically return. Plan capacity accordingly.
Best Practices
- List parents in priority order - First parent is preferred if all equal
- Configure at least 3 parents - Ensures availability during maintenance
- Monitor parent data completeness - Affects routing decisions
- Plan maintenance carefully - Children won't automatically return
