Skip to main content
Expanded Chart Analysis
Analyze your metrics in-depth with Netdata's Expanded Chart Analysis feature. Access detailed statistics, discover correlated metrics, and investigate anomalies directly from any chart.
Overview
The Expanded Chart Analysis feature provides an analytical panel below your charts. It gives you four ways to investigate your data: view detailed statistics, explore hierarchical relationships, compare time periods, and discover correlated metrics across your infrastructure.
No query language required—everything works with point-and-click.
Open the Analysis Panel
Click the Expand button at the bottom of any chart. The analysis panel opens below the chart with four analysis modes available.
expand button
When you're done, click Collapse to close the panel. Your settings persist and restore when you reopen it.
Select Your Time Range
Choose which time period to analyze using the tabs at the top of the panel:
Window analyzes the entire visible time range on the chart. This tab is always available and updates automatically when you zoom or pan the chart.
Selected Area analyzes a specific highlighted period. This tab activates when you highlight a time range on the chart (see Highlight a Time Range).
All analysis modes support both time range options.
Analysis Modes
Switch between modes by clicking the icons in the panel header. Each mode is designed for a specific type of investigation.
ModeIconUse For
Chart Values📊Viewing detailed statistics for all dimensions
Drill Down🔽Exploring which nodes or instances contribute most
Compare Periods📈Comparing current metrics with historical data
Correlate Metrics🔗Finding related metrics across your infrastructure
Chart Values
View detailed statistics for every dimension in your chart. This mode shows you the exact numbers behind the visualization.
chart values
ColumnDescription
DimensionDimension name with color indicator
ValueCurrent or hovering value with units
MinMinimum value in the time period
AvgAverage value in the time period
MaxMaximum value in the time period
AnomalyAnomaly rate (percentage of time behaving unusually)
tip
Sort by the Anomaly column to quickly find which dimensions are behaving strangely.
Show advanced statistics
Click the metrics icon in the panel header to reveal additional columns:
Advanced ColumnDescription
MedianMiddle value (50th percentile)
StdDevStandard deviation
P9595th percentile
RangeDifference between max and min
VolumeSum of all values
Sort and export
Click any column header to sort by that column. Click Download to export the data as CSV.
When to use this mode:
Use Chart Values when investigating spikes to see which specific dimensions are responsible. Sort by Anomaly to find unusual behavior, or check Max values to see peak usage.
Drill Down
Explore hierarchical relationships in your infrastructure. This mode organizes metrics into a three-level tree:
drill down
LevelDescriptionExamples
NodeIndividual servers or hostsserver-01, web-prod-03
InstanceSpecific entities being monitoreddisk "sda", network "eth0"
DimensionIndividual metrics"read", "write", "used"
Each level shows:
ColumnDescription
NameNode, instance, or dimension name with expand icon
ContributionPercentage weight (contribution to total)
Anomaly RateAggregated anomaly rate for this branch
MinMinimum value in period
AvgAverage value in period
MaxMaximum value in period
Navigate the hierarchy
Click the expand icon next to any row to drill into the next level. Click again to collapse. Click Group By to change how the hierarchy is organized.
info
The contribution percentage shows the weight of each item relative to the total. A node contributing 80% tells you that most of your metrics come from that server.
Use Drill Down to identify which node is using the most resources. Expand the Node level and sort by Contribution to see which servers contribute most. Click the node name to navigate to that node's dashboard.
Compare Periods
Compare current metrics with historical periods to identify trends and changes. This mode automatically shows comparisons with:
compare periods
PeriodDescription
CurrentThe visible time window or selected area (base period)
YesterdaySame duration, 24 hours ago
Last WeekSame duration, 7 days ago
Last MonthSame duration, 30 days ago
Each period card displays:
  • Period label and date range
  • Basic statistics (Min, Avg, Max)
  • Change indicators showing percentage and absolute change compared to current
IndicatorMeaning
🔴 RedIncrease from current period
🟢 GreenDecrease from current period
⚪ GrayNo significant change
Click the metrics icon in the panel header to reveal Median, StdDev, P95, Range, and Volume for each period. All statistics include change indicators.
Add custom periods
Compare with specific dates important to your analysis. Click Add Custom Period, enter a label (e.g., "Black Friday 2024"), set the start and end date/time, and click Add. The custom period appears in the comparison grid.
Click the edit icon on any custom period card to modify the label or date range.
warning
Historical data might not be available if it exceeds your retention settings. Use shorter comparison periods if you see errors.
Use Compare Periods to identify growth trends over time. Review Avg values across all periods to spot consistent increases or decreases. Export the data for capacity planning.
Correlate Metrics
Discover which metrics across your infrastructure correlate with the current chart's behavior. This mode shows you metrics that follow similar patterns, helping you find related issues.
correlate metrics
The table displays correlated metrics grouped by context:
ColumnDescription
ContextMetric category (grouped header)
MetricFull metric name (node:instance:dimension)
WeightCorrelation weight (lower = stronger correlation)
SparklineMini chart showing the metric's behavior
Choose your correlation method
Select how to calculate correlations:
MethodDescriptionBest For
VolumeIdentifies metrics with similar magnitude changesMost use cases (recommended)
KS2Uses statistical analysis for similar distributionsComplex pattern matching
Select aggregation
Choose how to aggregate data:
AggregationUse When
AverageGeneral patterns (recommended)
MedianOutliers might skew results
MinFocusing on minimum values
MaxFocusing on peak values
StdDevFocusing on variability
Adjust the threshold
Use the threshold slider to control how many results appear. Lower threshold (e.g., 0.1%) shows more results including weaker correlations. Higher threshold (e.g., 5%) shows fewer results with only the strongest correlations.
tip
Start with 1-2% threshold for most investigations. Increase the threshold if you see too many results, or decrease it if you need more options.
Navigate to correlated metrics
Click any metric row to navigate to that chart and investigate further.
Use Correlate Metrics when investigating a spike or anomaly. Highlight the problem period, switch to Selected Area tab, and review correlated metrics to find related issues across your infrastructure.
Focus your analysis on a specific time period by highlighting it on the chart.
Hold Alt (Windows/Linux) or (macOS), then click and drag across the chart to select a time range. The highlighted area appears with a visual overlay.
Once you create a highlight, the Selected Area tab becomes available in the analysis panel. Click it to view statistics and correlations for only the highlighted period.
To remove a highlight, click anywhere on the chart outside the highlighted area.
note
The Selected Area tab is disabled until you create a highlight on the chart.
Troubleshooting
The Selected Area tab is grayed out
You need to highlight a time range on the chart first. Hold Alt (or on macOS) and drag across the chart to create a highlight.
No correlated metrics appear
The threshold might be set too low. Try increasing the threshold slider to 1-5% to see the strongest correlations.
Drill Down shows "No data available"
This occurs when:
  • The time range is too short
  • No data was collected during this period
Try zooming out to a longer time range on the chart.
Compare mode shows errors for historical periods
Historical data might not be available due to retention settings. Try using shorter comparison periods (Yesterday instead of Last Month) or check your data retention configuration.
Advanced statistics columns are missing
Click the metrics icon button in the panel header to show advanced statistics (Median, StdDev, P95, Range, Volume).
The analysis panel is slow to load
For large time ranges or many dimensions:
  • Use a shorter time range
  • Highlight a specific area to analyze
  • Filter to fewer dimensions using the chart legend
