Skip to main content
Alert troubleshooting with Netdata Assistant
The Netdata Assistant is a feature that uses large language models and the Netdata community's collective knowledge to guide you during troubleshooting. It is designed to make understanding and root causing alerts simpler and faster.
Using Netdata Assistant
  • Navigate to the Alerts tab
  • If there are active alerts, the Actions column will have an Assistant button
    actions column
  • Clicking on the Assistant button opens up as a floating window with customized information and troubleshooting tips for this alert (note that the window can follow you through your troubleshooting journey on Netdata dashboards)
    Netdata Assistant popup
  • If you need more information or want to dig deeper into an issue, Netdata Assistant will also provide you with helpful web links to resources that can help you.
    useful resources
  • If there are no active alerts, you can still use Netdata Assistant by clicking the Assistant button on the Alert Configuration view.
