Skip to main content
Configuring Metrics Centralization Points
tip
What You'll Learn
How to configure streaming between Netdata Children and Parents using stream.conf, including basic setup, TLS/SSL encryption, and troubleshooting connection issues.
Metrics streaming configuration for both Netdata Children and Parents is done via stream.conf.
important
Configuration File Security
netdata.conf and stream.conf have the same ini format, but netdata.conf is considered a non-sensitive file, while stream.conf contains API keys, IPs and other sensitive information that enable communication between Netdata Agents.
Understanding stream.conf Structure
stream.conf has two main sections:
  • The [stream] section includes options for the sending Netdata (i.e., Netdata Children, or Netdata Parents that stream to Grand Parents, or to other sibling Netdata Parents in a cluster).
  • The rest includes multiple sections that define API keys for the receiving Netdata (i.e., Netdata Parents).
Edit stream.conf
To edit stream.conf, run this on your terminal:
cd /etc/netdata 2>/dev/null || cd /opt/netdata/etc/netdata
sudo ./edit-config stream.conf
Your editor will open, with defaults and commented stream.conf options.
note
If running Netdata in Docker, enter the container first with docker exec -it netdata bash, then run cd /etc/netdata && ./edit-config stream.conf inside it.
Configuration Steps
Configuring a Netdata Parent
To enable the reception of metrics from Netdata Children, generate a random API key with this command:
uuidgen
Then, copy the UUID generated, edit stream.conf, find the section that reads like the following and replace API_KEY with the UUID you generated:
[API_KEY]
# Accept metrics streaming from other Agents with the specified API key
enabled = yes
Save the file and restart Netdata.
Configuring Netdata Children
To enable streaming metrics to a Netdata Parent, edit stream.conf, and at the [stream] section at the top, set:
[stream]
# Stream metrics to another Netdata
enabled = yes
# The destination of the parent (hostname/FQDN or IP address) and PORT
destination = PARENT_HOSTNAME_OR_IP:19999
# The shared API key, generated by uuidgen
api key = API_KEY
Enable TLS/SSL Communication
While encrypting the connection between your parent and child nodes is recommended for security, it's not required to get started.
This example uses self-signed certificates.
note
Prerequisites
This section assumes you have read the documentation on how to edit the Netdata configuration files.
SSL Setup Process
  1. Parent node
    To generate an SSL key and certificate using openssl, take a look at the related section around Securing Netdata Agents in our Documentation.
  2. Child node
    Update stream.conf to enable SSL/TLS and allow self-signed certificates. Append ':SSL' to the destination and uncomment 'ssl skip certificate verification'.
    [stream]
    enabled = yes
    destination = 203.0.113.0:SSL
    ssl skip certificate verification = yes
    api key = 11111111-2222-3333-4444-555555555555
    note
    The :SSL suffix enables TLS encryption for Netdata's custom streaming protocol. This is different from HTTPS—Netdata streaming uses its own binary protocol over TCP, and TLS adds encryption on top of that protocol.
  3. Restart both nodes
    Restart the Netdata Agent on both the parent and child nodes to stream encrypted metrics using TLS/SSL.
Troubleshooting Streaming Connections
You can find any issues related to streaming at Netdata logs.
From the UI
Netdata logs to systemd-journald by default, and its logs are available at the Logs tab of the UI. At the MESSAGE_ID field look for Netdata connection from child and Netdata connection to parent.
From the terminal
On the Parents:
journalctl -r --namespace=netdata MESSAGE_ID=ed4cdb8f1beb4ad3b57cb3cae2d162fa
On the Children:
journalctl -r --namespace=netdata MESSAGE_ID=6e2e3839067648968b646045dbf28d66
Next Steps
Sizing Netdata Parents
After configuring your metrics centralization setup, you'll want to properly size your Netdata Parents to handle the expected load from your Children nodes.
For detailed information on resource requirements and optimization strategies, see Resource Utilization.
