Parent Configuration Best Practices
A Parent node is a Netdata Agent configured to receive metrics from multiple Child nodes. It acts as the central long-term storage layer, providing a unified view, longer retention, and high availability when used with replication.
Critical Factors to Consider
When setting up Parents, consider the following:
| Factor | Description | Impact |
| System Volume | The number of monitored systems | Larger infrastructures may need multiple Parents to maintain performance |
| Data Transfer Costs | Bandwidth usage between environments | Strategic placement reduces egress bandwidth costs in multi-cloud or hybrid environments |
| Usability Without Netdata Cloud | Standalone operation considerations | Fewer Parents simplifies access and management |
| Optimized Deployment with Netdata Cloud | Cloud integration benefits | Provides complete infrastructure view with optimized security, cost, and operational controls |
| Data Retention & Metric Volume | Disk planning for Parent nodes | Estimate disk needs based on total metrics streamed from children and configured retention tiers |
Deployment Optimization Factors
Critical Retention Configuration
Default retention settings will not work for production. Netdata defaults to 1GB space limit per tier with combined time/space retention. You'll hit the 1GB limit within hours or days, causing data loss much sooner than your configured time limits.
You must configure retention properly before deployment.
Choosing Your Retention Strategy
Netdata supports three retention strategies. Choose the one that best fits your environment:
Time-based retention (recommended for predictable retention periods):
Guarantees data is kept for a fixed time, regardless of disk usage (assuming you have enough disk space)
[db]
dbengine tier 0 retention time = 30d
dbengine tier 0 retention size = 0
dbengine tier 1 retention time = 6mo
dbengine tier 1 retention size = 0
dbengine tier 2 retention time = 5y
dbengine tier 2 retention size = 0 -
Space-based retention (recommended for predictable disk usage):
Guarantees storage usage stays within defined limits, at the cost of variable retention duration.
[db]
dbengine tier 0 retention size = 500GB
dbengine tier 0 retention time = 0
dbengine tier 1 retention size = 200GB
dbengine tier 1 retention time = 0
dbengine tier 2 retention size = 100GB
dbengine tier 2 retention time = 0 -
Combined retention (use with caution):
Uses both time and space limits. Data is dropped as soon as either limit is reached.
[db]
dbengine tier 0 retention size = 500GB # Must be large enough to hold 30 days of data!
dbengine tier 1 retention size = 200GB # Must be large enough to hold 6 months of data!
dbengine tier 2 retention size = 100GB # Must be large enough to hold 5 years of data!
- For Parent nodes with millions of metrics, expect to allocate 100GB-1TB+ per tier.
- Setting
retention size = 0means unlimited space (not zero space). This works well with time-based retention if you have sufficient disk capacity. - Always validate retention sizing in staging before production to avoid premature data loss.
Estimating Disk Retention by Metric Volume on Parent Nodes
Parent nodes are the central long-term storage layer in a Netdata infrastructure. They receive all metrics streamed from children and store them according to tiered retention settings.
| Tier | Sample Resolution | Typical Compressed Size per Sample |
| Tier 0 | per second (native) | ~0.6 B / sample |
| Tier 1 | per minute (60× aggregate) | ~6 B / sample |
| Tier 2 | per hour (60× aggregate of Tier 1) | ~18 B / sample |
Example Calculation
Assume a Parent configured with:
- Tier 0: 30 days retention (per-second resolution)
- Tier 1: 6 months retention (per-minute resolution)
- Tier 2: 5 years retention (per-hour resolution)
One metric would consume approximately 3.7 MB across tiers. For 1,000,000 metrics streamed to the Parent, this equals ≈ 3.7 TB.
Adding 5–15% overhead for replication buffers, indexes, and metadata, plan for ≈ 4 TB per million metrics under this retention policy.
Configuration Example for Production Deployments
[db]
mode = dbengine
update every = 1
storage tiers = 3
# Tier 0: per-second data for 30 days
# No size limit - let time control retention
# Tier 1: per-minute data for 6 months
dbengine tier 1 update every iterations = 60
# Tier 2: per-hour data for 5 years
dbengine tier 2 update every iterations = 60
Cost Optimization Strategies
Netdata helps you keep observability efficient and cost-effective:
| Strategy | Description | Benefit |
| Scale Out | Use multiple smaller Parents | Improves efficiency and performance across distributed systems |
| Use Existing Resources | Leverage spare capacity | Minimize additional hardware costs by using available resources |
| Centralized or Separate Logs & Metrics | Choose storage approach based on needs | Optimize based on access patterns, retention policies, and compliance requirements |
| Flexible Configuration Management | Customize each Parent | Control costs with unique retention and alert settings tailored for different teams or services |
| Right-size Retention Based on Metrics | Tune tier retention and sampling | Directly control disk cost by shortening or lengthening retention tiers where appropriate |
Advantages of Netdata's Approach
Netdata provides several benefits over other observability solutions:
| Advantage | Description | Value |
| Scalability & Flexibility | Multiple independent Parents | Customized observability by region, service, or team |
| Resilience & Reliability | Built-in replication | Observability continues even if a Parent fails |
| Optimized Cost & Performance | Distributed workloads | Prevents bottlenecks and improves resource efficiency |
| Ease of Use | Minimal setup and maintenance | Reduces complexity and operational overhead |
| On-Prem Control | Data remains within your infrastructure | Enhanced security and compliance, even when using Netdata Cloud |
| Comprehensive Observability | Segmented infrastructure with unified view | Deep visibility with tailored retention, alerts, and machine learning |
| Predictable Capacity Planning | Published per-metric storage cost | Allows accurate disk and hardware sizing for Parents |
Following these best practices helps you maintain a cost-effective, high-performance observability setup with Netdata.
