Skip to main content
Metrics Tab and Single Node Tabs
The Metrics tab provides real-time, per-second time series charts for all nodes in a Room. It helps you visualize, explore, and troubleshoot metrics across your entire infrastructure in one place.
You can also view single-node dashboards, which offer the same charts but are focused on a single node. You can access these dashboards from most places in the Netdata UI, often by clicking the name of a node.
From the Metrics tab, you can also access:
  • The Integrations tab
  • Metric Correlations to identify related metrics and uncover patterns across your infrastructure
Metrics Tab Structure Overview​
tip
The diagram above shows how the Metrics tab connects to related features and single-node dashboards, making it easier to navigate between views.
How the Dashboard is Organized​
The dashboard displays various charts organized by their context. At the beginning of each section, there is a predefined arrangement of charts that provides an overview for that particular group of metrics — including the first section, which summarizes the node's overall system resources such as CPU, memory, disk, and network. The exact charts and gauges shown depend on the node's hardware and enabled collectors.
The available chart types and grouping options allow flexible data visualization for troubleshooting and analysis.
tip
Use the chart arrangement at the start of each section to quickly identify patterns, spikes, or anomalies before diving into detailed chart filtering.
Chart Navigation Menu​
The Chart Navigation Menu, located on the right-hand side of the dashboard, helps you navigate through sections, filter charts, and view active alerts.
FeatureDescription
Section NavigationNavigate quickly through the dashboard sections.
Chart Filtering OptionsFilter charts by:
- Host labels
- Node status
- Netdata version
- Individual nodes
Active Alerts DisplayView active alerts for the Room.
Anomaly Rate (AR%) ButtonCheck the maximum chart anomaly rate for each section by clicking the AR% button.
tip
Use chart filtering to reduce visual noise and focus on the nodes, labels, or statuses that matter most to your investigation.
tip
The AR% button shows the maximum anomaly rate for each dashboard section, helping you quickly identify where issues may be occurring.
