Skip to main content
Node Types and Lifecycle Strategies
Netdata categorizes nodes as ephemeral or permanent to help you tailor alerting, cleanup, and monitoring strategies for dynamic or static infrastructures.
Node Types
TypeDescriptionCommon Use Cases
EphemeralExpected to disconnect or reconnect frequently• Auto-scaling cloud instances
• Dynamic containers and VMs
• IoT devices with intermittent connectivity
• Test environments
PermanentExpected to maintain continuous connectivity• Production servers
• Core infrastructure nodes
• Critical monitoring systems
• Stable database servers
note
Disconnections in permanent nodes may indicate system failures and require immediate attention.
Key Benefits of Ephemeral Nodes
  1. Reduced Alert Noise: Disconnection alerts apply only to permanent nodes.
  2. Support for Dynamic Infrastructure: Designate temporary resources as ephemeral to avoid false alarms.
  3. Automated Cleanup: Configure retention policies for ephemeral nodes to keep dashboards uncluttered.
Configuring Ephemeral Nodes
By default, Netdata treats all nodes as permanent. To mark a node as ephemeral:
  1. Open the netdata.conf file on the target node.
  2. Add the following configuration:
    is ephemeral node = yes
  3. Restart the Netdata Agent.
Once restarted, Netdata automatically applies the _is_ephemeral host label to the node. This label propagates to your Parent nodes and appears in Netdata Cloud, allowing the system to identify and handle the node as ephemeral.
Alerts for Parent Nodes
Netdata v2.3.0 introduces two alerts specific to permanent nodes:
AlertTrigger Condition
streaming_never_connectedA permanent node has never connected to a Parent.
streaming_disconnectedA previously connected permanent node has disconnected.
important
Both alerts are configured with to: silent by default. They trigger and appear on the Parent dashboard but do not send notifications unless you explicitly enable them. They also apply only to permanent nodes — ephemeral nodes are excluded.
Enabling Notifications for Streaming Alerts
  1. Override each alert to send notifications. Choose one method:
    Via Netdata Cloud (recommended): Use the Alerts Configuration Manager to edit streaming_disconnected and streaming_never_connected on the Parent node. The UI creates a dynamic configuration that takes precedence over the stock template. See Alert Configuration Ordering for details. Repeat for both alerts.
    Via config file: On the Parent node, create or edit /etc/netdata/health.d/streaming.conf. An override must be a complete alert definition (see Overriding Stock Alerts); change to: silent to a role. sysadmin is the convention used by the stock alerts; any string is accepted:
         template: streaming_disconnected
    on: netdata.streaming_inbound
    class: Availability
    type: Streaming
    component: Streaming
    chart labels: type=permanent
    calc: ${stale disconnected}
    units: nodes
    every: 10s
    warn: $netdata.uptime.uptime > 30 * 60 AND $this > 0
    delay: up 5m down 5m multiplier 1.5 max 30m
    summary: Permanent streaming nodes disconnected
    info: Permanent child nodes disconnected from this parent. \
    If nodes are expected to disconnect, mark them as ephemeral, by editing their netdata.conf \
    and setting: [global].is ephemeral node = yes
    to: sysadmin
    Repeat for streaming_never_connected — note that template, calc, summary, and info all differ:
         template: streaming_never_connected
    class: Availability
    type: Streaming
    calc: ${stale archived}
    units: nodes
    every: 10s
    summary: Permanent streaming nodes never connected
    info: Permanent child nodes never connected to this parent. \
    If these nodes should actually be ephemeral, run: \
    netdatacli mark-stale-nodes-ephemeral ALL_NODES
    to: sysadmin
    After saving the file, reload health on the Parent:
    sudo netdatacli reload-health
    Make sure the role you choose has recipients wired up in your notification method(s) — see Centralized Cloud Notifications for Cloud setup.
  2. Enable Cloud notifications. An administrator must enable Alert notifications for the Space. Without this step, Netdata Cloud will not forward any alert notifications.
See also: Centralized Cloud Notifications for notification setup, and Node States and Transitions for troubleshooting node offline states.
Automatic Node Instance Cleanup in Netdata Cloud
Netdata Cloud automatically removes inactive nodes to keep your dashboards clean and organized.
Cleanup Rules
Node TypeOffline DurationDescription
Child nodes48 hoursNodes that connect through a Parent node. Deleted when:
• The child node goes offline, OR
• The Parent node goes offline
Directly connected nodes7 daysNodes claimed directly to Netdata Cloud without going through a Parent.
Ephemeral nodesCustomTemporary nodes (containers, auto-scaling VMs) with configurable cleanup periods. See configuration below.
Unseen nodes48 hoursNodes that were claimed but have never connected to Netdata Cloud.
tip
Stale nodes are NOT automatically deleted. Only Offline and Unseen nodes are subject to automatic cleanup. A Stale node has historical data available via a Parent, so it's preserved until the Parent goes offline or the data expires.
Important
If a child node is deleted and later reconnects, it's automatically recreated in Netdata Cloud. Any historical data retained on the Parent node remains accessible.
Monitoring and Managing Node Status
Mark Permanently Offline Nodes as Ephemeral
To mark nodes (including virtual ones) as ephemeral:
netdatacli mark-stale-nodes-ephemeral <node_id | machine_guid | hostname | ALL_NODES>
This keeps historical data queryable and clears active alerts.
Removing Offline Nodes
To fully remove permanently offline nodes:
netdatacli remove-stale-node <node_id | machine_guid | hostname | ALL_NODES>
note
For detailed instructions on removing nodes from Netdata Cloud (including offline and stale nodes, bulk operations, and UI-based removal), see the Remove Node Guide. This covers scenarios where UI removal is disabled due to parent-child configured relationships.
Automatically Removing Ephemeral Nodes
To enable automatic cleanup of ephemeral nodes:
  1. Open the netdata.conf file on Netdata Parent nodes.
    [db]
    cleanup ephemeral hosts after = 1d
This removes ephemeral nodes after 24 hours of disconnection. Once all Parents purge the node, it is automatically removed from Netdata Cloud.
See Also
  • Node States and Transitions - Comprehensive reference for node states (Live, Stale, Offline, Unseen) and transition triggers
  • Node Identities - Understand how node identity works alongside ephemerality
  • VM Templates - Configure ephemerality in VM templates for auto-scaling groups
