Organize systems, metrics, and alerts
When you use Netdata to monitor and troubleshoot an entire infrastructure, you need sophisticated ways of keeping everything organized. Netdata allows to organize your observability infrastructure with spaces, war rooms, virtual nodes, host labels, and metric labels.
Spaces and war rooms
Spaces are used for organization-level or infrastructure-level grouping of nodes and people. A node can only appear in a single space, while people can have access to multiple spaces.
The war rooms in a space bring together nodes and people in collaboration areas. War rooms can also be used for fine-tuned role based access control.
Virtual nodes
Netdata’s virtual nodes functionality allows you to define nodes in configuration files and have them be treated as regular nodes in all of the UI, dashboards, tabs, filters etc. For example, you can create a virtual node each for all your Windows machines and monitor them as discrete entities. Virtual nodes can help you simplify your infrastructure monitoring and focus on the individual node that matters.
To define your windows server as a virtual node you need to:
Define virtual nodes in
/etc/netdata/vnodes/vnodes.conf
- hostname: win_server1
guid: <value>Just remember to use a valid guid (On Linux you can use
uuidgen
command to generate one, on Windows just use the[guid]::NewGuid()
command in PowerShell)Add the vnode config to the data collection job. e.g. in
go.d/windows.conf
:jobs:
- name: win_server1
vnode: win_server1
url: http://203.0.113.10:9182/metrics
Host labels
Host labels can be extremely useful when:
- You need alarms that adapt to the system's purpose
- You need properly-labeled metrics archiving so you can sort, correlate, and mash-up your data to your heart's content.
- You need to keep tabs on ephemeral Docker containers in a Kubernetes cluster.
Let's take a peek into how to create host labels and apply them across a few of Netdata's features to give you more organization power over your infrastructure.
Default labels
When Netdata starts, it captures relevant information about the system and converts them into automatically generated host labels. You can use these to logically organize your systems via health entities, exporting metrics, parent-child status, and more.
They capture the following:
- Kernel version
- Operating system name and version
- CPU architecture, system cores, CPU frequency, RAM, and disk space
- Whether Netdata is running inside of a container, and if so, the OS and hardware details about the container's host
- Whether Netdata is running inside K8s node
- What virtualization layer the system runs on top of, if any
- Whether the system is a streaming parent or child
If you want to organize your systems without manually creating host labels, try the automatic labels in some of the
features below. You can see them under http://HOST-IP:19999/api/v1/info
, beginning with an underscore _
"host_labels": {
"_is_k8s_node": "false",
"_is_parent": "false",
Custom labels
Host labels are defined in netdata.conf
. To create host labels, open that file using edit-config
cd /etc/netdata # Replace this path with your Netdata config directory, if different
sudo ./edit-config netdata.conf
Create a new [host labels]
section defining a new host label and its value for the system in question. Make sure not
to violate any of the host label naming rules.
[host labels]
type = webserver
location = us-seattle
installed = 20200218
Once you've written a few host labels, you need to enable them. Instead of restarting the entire Netdata service, you
can reload labels using the helpful netdatacli
tool:
netdatacli reload-labels
Your host labels will now be enabled. You can double-check these by using curl http://HOST-IP:19999/api/v1/info
to
read the status of your agent. For example, from a VPS system running Debian 10:
"host_labels": {
"_virt_detection": "systemd-detect-virt",
"_container_detection": "none",
"_container": "unknown",
"_virtualization": "kvm",
"_architecture": "x86_64",
"_kernel_version": "4.19.0-6-amd64",
"_os_version": "10 (buster)",
"_os_name": "Debian GNU/Linux",
"type": "webserver",
"location": "seattle",
"installed": "20200218"
Host labels in streaming
You may have noticed the _is_parent
and _is_child
automatic labels from above. Host labels are also now
streamed from a child to its parent node, which concentrates an entire infrastructure's OS, hardware, container,
and virtualization information in one place: the parent.
Now, if you'd like to remind yourself of how much RAM a certain child node has, you can access
http://localhost:19999/host/CHILD_HOSTNAME/api/v1/info
and reference the automatically-generated host labels from the
child system. It's a vastly simplified way of accessing critical information about your infrastructure.
⚠️ Because automatic labels for child nodes are accessible via API calls, and contain sensitive information like kernel and operating system versions, you should secure streaming connections with SSL. See the streaming documentation for details. You may also want to use access lists or expose the API only to LAN/localhost connections.
You can also use _is_parent
, _is_child
, and any other host labels in both health entities and metrics
exporting. Speaking of which...
Host labels in alerts
You can use host labels to logically organize your systems by their type, purpose, or location, and then apply specific alarms to them.
For example, let's use configuration example from earlier:
[host labels]
type = webserver
You could now create a new health entity (checking if disk space will run out soon) that applies only to any host
labeled webserver
template: disk_fill_rate
on: disk.space
lookup: max -1s at -30m unaligned of avail
calc: ($this - $avail) / (30 * 60)
every: 15s
host labels: type = webserver
Or, by using one of the automatic labels, for only webserver systems running a specific OS:
host labels: _os_name = Debian*
In a streaming configuration where a parent node is triggering alarms for its child nodes, you could create health entities that apply only to child nodes:
host labels: _is_child = true
Or when ephemeral Docker nodes are involved:
host labels: _container = docker
Of course, there are many more possibilities for intuitively organizing your systems with host labels. See the health documentation for more details, and then get creative!
Host labels in metrics exporting
If you have enabled any metrics exporting via our experimental exporters, any new host
labels you created manually are sent to the destination database alongside metrics. You can change this behavior by
editing exporting.conf
, and you can even send automatically-generated labels on with exported metrics.
[exporting:global]
enabled = yes
send configured labels = yes
send automatic labels = no
You can also change this behavior per exporting connection:
[opentsdb:my_instance3]
enabled = yes
destination = localhost:4242
data source = sum
update every = 10
send charts matching = system.cpu
send configured labels = no
send automatic labels = yes
By applying labels to exported metrics, you can more easily parse historical metrics with the labels applied. To learn more about exporting, read the documentation.
Metric labels
The Netdata aggregate charts allow you to filter and group metrics based on label name-value pairs.
All go.d plugin collectors support the specification of labels at the "collection job" level. Some collectors come with out of the box labels (e.g. generic Prometheus collector, Kubernetes, Docker and more). But you can also add your own custom labels, by configuring the data collection jobs.
For example, suppose we have a single Netdata agent, collecting data from two remote Apache web servers, located in different data centers. The web servers are load balanced and provide access to the service "Payments".
You can define the following in go.d.conf
, to be able to group the web requests by service or location:
jobs:
- name: mywebserver1
url: http://host1/server-status?auto
labels:
service: "Payments"
- name: mywebserver2
url: http://host2/server-status?auto
labels:
service: "Payments"
Of course you may define as many custom label/value pairs as you like, in as many data collection jobs you need.
