Exporting Reference
This reference guide provides comprehensive information about enabling, configuring, and monitoring Netdata's exporting engine for sending metrics to external time-series databases.
For a quick introduction, read our exporting metrics overview or start with enabling a connector.
Core Capabilities
The exporting engine features a modular structure that supports:
- Multiple connector instances running simultaneously
- Different update intervals per connector
- Custom filters per connector instance
- Metric resampling to reduce database congestion
When you enable the exporting engine, Netdata exports metrics starting from the restart time, not the entire historical database.
Operation Modes
Netdata provides three data export modes:
| Mode | Description | Data Format | Use Case |
| as-collected | Raw metrics in original units | Counters remain counters, gauges remain gauges | Time-series database experts who need raw data |
| average | Normalized metrics from Netdata database | All metrics sent as gauges in Netdata units | Simplified visualization with Netdata-centric workflows |
| sum/volume | Sum of interpolated values | Aggregated values over the export interval | Long-term trend analysis |
Choosing the Right Mode:
- Use
as-collectedif you're building monitoring around a time-series database and know how to convert units - Use
averagefor simpler long-term archiving that matches Netdata's visualization exactly
Supported Connectors
| Connector | Protocol/Format | Metric Format |
| AWS Kinesis | JSON | Stream-based |
| Google Pub/Sub | JSON | Message-based |
| Graphite | Plaintext | prefix.hostname.chart.dimension |
| JSON Databases | JSON | Document-based |
| OpenTSDB | Plaintext/HTTP | prefix.chart.dimension with tags |
| MongoDB | JSON | Document-based |
| Prometheus | HTTP scraping | Prometheus exposition format |
| Prometheus Remote Write | Snappy-compressed protobuf | Binary over HTTP |
| TimescaleDB | JSON streams | Time-series tables |
Configuration Structure
Your exporting.conf file contains these configuration blocks:
[exporting:global]
enabled = yes
send configured labels = no
send automatic labels = no
update every = 10
[prometheus:exporter]
send names instead of ids = yes
send configured labels = yes
send charts matching = *
send hosts matching = localhost *
prefix = netdata
[graphite:my_graphite_instance]
enabled = yes
destination = localhost:2003
data source = average
prefix = Netdata
hostname = my-name
update every = 10
buffer on failures = 10
timeout ms = 20000
send automatic labels = yes
[prometheus_remote_write:my_prometheus_remote_write_instance]
enabled = yes
remote write URL path = /receive
[kinesis:my_kinesis_instance]
enabled = yes
destination = us-east-1
stream name = netdata
aws_access_key_id = my_access_key_id
aws_secret_access_key = my_aws_secret_access_key
[pubsub:my_pubsub_instance]
enabled = yes
destination = pubsub.googleapis.com
credentials file = /etc/netdata/pubsub_credentials.json
project id = my_project
topic id = my_topic
[mongodb:my_mongodb_instance]
enabled = yes
database = my_database
collection = my_collection
[json:my_json_instance]
enabled = yes
destination = localhost:5448
[opentsdb:my_opentsdb_plaintext_instance]
enabled = yes
destination = localhost:4242
[opentsdb:http:my_opentsdb_http_instance]
enabled = yes
username = my_username
password = my_password
[opentsdb:https:my_opentsdb_https_instance]
enabled = yes
destination = localhost:8082
Configuration Sections
| Section | Purpose |
[exporting:global] | Default settings for all connectors |
[prometheus:exporter] | Prometheus API endpoint settings |
[<type>:<name>] | Individual connector instance configuration |
Connector Types
Available connector types with optional modifiers:
graphite|graphite:http|graphite:httpsopentsdb:telnet|opentsdb:http|opentsdb:httpsprometheus_remote_write|prometheus_remote_write:http|prometheus_remote_write:httpsjson|json:http|json:httpskinesis|pubsub|mongodb
Configuration Options
Basic Settings
| Option | Values | Description |
enabled | yes/no | Activates the connector instance |
data source | as-collected/average/sum | Selects data export mode |
hostname | string | Hostname for external database (default: [global].hostname) |
prefix | string | Prefix added to all metrics |
update every | seconds | Export interval with automatic randomization |
Connection Settings
| Option | Format | Description |
destination | space-separated list | Target servers in [PROTOCOL:]IP[:PORT] format |
buffer on failures | iterations | Buffer size when database unavailable |
timeout ms | milliseconds | Processing timeout (default: 2 * update_every * 1000) |
Destination Examples
IPv4 configuration:
destination = 10.11.14.2:4242 10.11.14.3:4242 10.11.14.4:4242
IPv6 and IPv4 combined:
destination = [ffff:...:0001]:2003 10.11.12.1:2003
Special destinations:
- Kinesis: AWS region (e.g.,
us-east-1) - MongoDB: MongoDB URI
- Pub/Sub: Service endpoint
Filtering Options
| Option | Pattern Format | Description |
send hosts matching | space-separated patterns | Filter hosts using * wildcard, ! for negation |
send charts matching | space-separated patterns | Filter charts by ID/name, ! for negation |
Pattern matching follows first-match logic. Order matters when using negative patterns (!).
Example: !*child* *db* matches all *db* hosts except those containing *child*.
Label Settings
send names instead of ids | yes/no | Use human-friendly names vs system IDs |
send configured labels | yes/no | Include [host labels] from netdata.conf |
send automatic labels | yes/no | Include auto-generated labels (_os_name, _architecture) |
Chart Filtering
Filter metrics through two methods:
Configuration file:
[prometheus:exporter]send charts matching = system.* -
URL parameter:
http://localhost:19999/api/v1/allmetrics?format=shell&filter=system.*
HTTPS Support
For databases without native TLS/SSL support, configure a reverse proxy:
Performance Considerations
The exporting engine operates independently to avoid slowing down Netdata. However:
Multiple connector instances running batches simultaneously can consume significant CPU resources. Configure different update intervals to prevent synchronization.
Monitoring the Exporting Engine
Netdata provides five monitoring charts under Netdata Monitoring:
| Chart | Monitors |
| Buffered metrics | Number of metrics added to dispatch buffer |
| Exporting data size | Data volume (KB) added to buffer |
| Exporting operations | Operation count performed |
| Exporting thread CPU usage | CPU resources consumed by exporting thread |
Built-in Alerts
The exporting engine includes three automatic alerts:
| Alert | Monitors |
exporting_last_buffering | Seconds since last successful buffering |
exporting_metrics_sent | Percentage of successfully sent metrics |
exporting_metrics_lost | Metrics lost due to repeated failures |
Fallback Script
Netdata includes nc-exporting.sh for:
- Saving metrics to disk during database outages
- Pushing cached metrics when database recovers
- Monitoring/tracing/debugging metric generation
