Shell exporter
Shell scripts can now query Netdata:
eval "$(curl -s 'http://localhost:19999/api/v3/allmetrics')"
after this command, all the Netdata metrics are exposed to shell. Check:
# source the metrics
# let's see if there are variables exposed by Netdata for system.cpu
set | grep "^NETDATA_SYSTEM_CPU"
NETDATA_SYSTEM_CPU_GUEST=0
NETDATA_SYSTEM_CPU_GUEST_NICE=0
NETDATA_SYSTEM_CPU_IDLE=95
NETDATA_SYSTEM_CPU_IOWAIT=0
NETDATA_SYSTEM_CPU_IRQ=0
NETDATA_SYSTEM_CPU_NICE=0
NETDATA_SYSTEM_CPU_SOFTIRQ=0
NETDATA_SYSTEM_CPU_STEAL=0
NETDATA_SYSTEM_CPU_SYSTEM=1
NETDATA_SYSTEM_CPU_USER=4
NETDATA_SYSTEM_CPU_VISIBLETOTAL=5
# let's see the total cpu utilization of the system
echo $\{NETDATA_SYSTEM_CPU_VISIBLETOTAL}
5
# what about alerts?
set | grep "^NETDATA_ALARM_SYSTEM_SWAP_"
NETDATA_ALARM_SYSTEM_SWAP_USED_SWAP_STATUS=CLEAR
NETDATA_ALARM_SYSTEM_SWAP_USED_SWAP_VALUE=51
# let's get the current status of the alert 'used swap'
echo $\{NETDATA_ALARM_SYSTEM_SWAP_USED_SWAP_STATUS}
CLEAR
# is it fast?
time curl -s 'http://localhost:19999/api/v3/allmetrics' >/dev/null
real 0m0,070s
user 0m0,000s
sys 0m0,007s
# it is...
# 0.07 seconds for curl to be loaded, connect to Netdata and fetch the response back...
The _VISIBLETOTAL
variable sums up all the dimensions of each chart.
The format of the variables is:
NETDATA_$\{chart_id^^}_$\{dimension_id^^}="$\{value}"
The value is rounded to the closest integer, since shell script cannot process decimal numbers.
