BGP Monitoring
Netdata monitors the BGP sessions on your routers — peer state, the prefixes they exchange, and the health of each session — so you see when a peer goes down, flaps, or quietly stops sending updates.
What Netdata watches
For every BGP peer on a monitored router:
- Session state — Established, or where in the lifecycle it sits.
- Uptime and stability — how long the session has held, and how often it has flapped.
- Prefixes — per address family, the routes exchanged (received, accepted, active, advertised, rejected, suppressed, withdrawn), where the device reports them.
- Update recency — how long since the peer last sent an update.
- Last-down detail — the last error, down reason, and graceful-restart state, where the vendor MIB reports them.
Session and traffic metrics appear as live charts per peer; the full per-peer detail is in the snmp:bgp-peers function, a sortable table of every peer.
Up-but-stale detection
A BGP session can show Established while it has quietly stopped receiving routes — the session looks fine, but the routing behind it is stale. Netdata tracks the time since each peer's last update, so an up-but-stale peer (state Established, last-update age climbing) is visible.
Which devices
Any router that exposes its peers over the standard BGP4-MIB, with vendor BGP profiles for Alcatel-Lucent, Arista, Cisco, Dell, Huawei, Juniper, and Nokia adding per-vendor detail. It comes up automatically with the device's profile.
Alerts
Stock alerts for BGP health — a peer or address family dropping out of Established, plus ML-based anomaly alerts on session-transition rate, update churn, and accepted-prefix drift.
Where to start
- BGP comes up automatically when you monitor a router that runs it — open its charts or the
snmp:bgp-peersfunction.
