Skip to main content
Database engine
DBENGINE is the time-series database of Netdata.
Design​
Data Points​
Data points represent the collected values of metrics.
A data point has:
  1. A value, the data collected for a metric. There is a special value to indicate that the collector failed to collect a valid value, and thus the data point is a gap.
  2. A timestamp, the time it has been collected.
  3. A duration, the time between this and the previous data collection.
  4. A flag which is set when machine-learning categorized the collected value as anomalous (an outlier based on the trained models).
Using the timestamp and duration, Netdata calculates for each point its start time, end time and update every.
For incremental metrics (counters), Netdata interpolates the collected values to align them to the expected end time at the microsecond level, absorbing data collection micro-latencies.
When data points are stored in higher tiers (time aggregations - see Tiers below), each data point has:
  1. The sum of the original values that have been aggregated
  2. The count of all the original values aggregated,
  3. The minimum value among them,
  4. The maximum value among them,
  5. Their anomaly rate, i.e., the count of values that were detected as outliers based on the currently trained models for the metric
  6. A timestamp, which is the equal to the end time of the last point aggregated,
  7. A duration, which is the duration between the first time of the first point aggregated to the end time of the last point aggregated.
This design allows Netdata to accurately know the average, minimum, maximum and anomaly rate values even when using higher tiers to satisfy a query.
Pages​
Data points are organized into pages, i.e., segments of contiguous data collections of the same metric.
Each page:
  1. Contains contiguous data points of a single metric.
  2. Contains data points having the same update every. If a metric changes update every on the fly, the page is flushed and a new one with the new update every is created. If a data collection is missed, a gap point is inserted into the page, so that the data points in a page remain contiguous.
  3. Has a start time, which is equivalent to the end time of the first data point stored into it,
  4. Has an end time, which is equal to the end time of the last data point stored into it,
  5. Has an update every, common for all points in the page.
A page is a simple array of values. Each slot in the array has a timestamp implied by its position in the array, and each value stored represents the data point for that time, for the metric the page belongs to.
This fixed step page design allows Netdata to collect several millions of points per second and pack all the values in a compact form with minimal metadata overhead.
Hot Pages​
While a metric is collected, there is one hot page in memory for each of the configured tiers. Values collected for a metric are appended to its hot page until that page becomes full.
Dirty Pages​
Once a hot page is full, it becomes a dirty page, and it is scheduled for immediate flushing (saving) to disk.
Clean Pages​
Flushed (saved) pages are clean pages, i.e., read-only pages that reside primarily on disk, and are loaded on demand to satisfy data queries.
Pages Configuration​
Pages are configured like this:
AttributeTier0Tier1Tier2
Point Size in Memory, in Bytes41616
Point Size on Disk, in Bytes
after LZ4 compression, on the average
144
Page Size in Bytes4096
2048 in 32bit
2048
1024 in 32bit
384
192 in 32bit
Collections per Point160x Tier0
configurable in
netdata.conf
60x Tier1
configurable in
netdata.conf
Points per Page1024
512 in 32bit
128
64 in 32bit
24
12 in 32bit
Files​
To minimize the amount of data written to disk and the amount of storage required for storing metrics, Netdata aggregates up to 64 dirty pages of independent metrics, packs them all together into one bigger buffer, compresses this buffer with LZ4 (about 75% savings on the average) and commits a transaction to the disk files.
Extents​
This collection of 64 pages that is packed and compressed together is called an extent. Netdata tries to store together, in the same extent, metrics that are meant to be "close". Dimensions of the same chart are such. They are usually queried together, so it is beneficial to have them in the same extent to read all of them at once at query time.
Datafiles​
Multiple extents are appended to datafiles (filename suffix .ndf) until these datafiles become full. The size of each datafile is determined automatically by Netdata. Depending on the amount of disk space configured for each tier, Netdata chooses a target datafile size and clamps it between the compiled minimum and maximum datafile sizes. The current target is to keep about 100 datafiles for the tier.
Journal Files​
Each datafile has two journal files with metadata related to the stored data in the datafile.
  • journal file v1, with filename suffix .njf, holds information about the transactions in its datafile and provides the ability to recover as much data as possible, in case either the datafile or the journal files get corrupted. This journal file has a maximum transaction size of 4KB, so in case data are corrupted on disk transactions of 4KB are lost. Each transaction holds the metadata of one extent (this is why DBENGINE supports up to 64 pages per extent).
  • journal file v2, with filename suffix .njfv2, which is a disk-based index for all the pages and extents. This file is memory mapped at runtime and is consulted to find where the data of a metric are in the datafile. This journal file is automatically re-created from journal file v1 if it is missing. It is safe to delete these files (when Netdata does not run). Netdata will re-create them on the next run. Journal files v2 are supported in Netdata Agents with version netdata-1.37.0-115-nightly. Older versions maintain the journal index in memory.
Database Rotation​
Database rotation is achieved by deleting the oldest datafile (and its journals) and creating a new one (with its journals).
Data on disk are append-only. There is no way to delete, add, or update data in the middle of the database. If data are not useful for whatever reason, Netdata can be instructed to ignore these data. They will eventually be deleted from the disk when the database is rotated. New data are always appended.
Tiers​
Tiers are supported in Netdata Agents with version netdata-1.35.0.138.nightly and greater.
datafiles and journal files are organized in tiers. All tiers share the same metrics and same collected values.
  • tier 0 is the high resolution tier that stores the collected data at the frequency they are collected.
  • tier 1 by default aggregates 60 values of tier 0.
  • tier 2 by default aggregates 60 values of tier 1, or 3600 values of tier 0.
Updating the higher tiers is automated, and it happens in real-time while data are being collected for tier 0.
When the Netdata Agent starts, during the first data collection of each metric, higher tier are automatically backfilled with data from lower tiers, so that the aggregation they provide will be accurate.
Configuring how the number of tiers and the disk space allocated to each tier is how you can change how long netdata stores metrics.
For how update every controls each tier's granularity and interacts with retention time and disk size, see Update Every and Tier Granularity.
Data loss​
Until hot pages and dirty pages are flushed to disk, they are at risk (e.g., due to a crash, or power failure), as they are stored only in memory.
The supported way of ensuring high data availability is the use of Netdata Parents to stream the data in real-time to multiple other Netdata Agents.
Memory requirements and retention​
See change how long netdata stores metrics
Exceptions​
Netdata has several protection mechanisms to prevent the use of more memory (than the above), by incrementally fetching data from disk and aggressively evicting old data to make Room for new data, but still memory may grow beyond the above limit under the following conditions:
  1. The number of pages concurrently used in queries does not fit in the above size. This can happen when multiple queries of unreasonably long time-frames run on lower, higher resolution tiers. The Netdata query planner attempts to avoid such situations by gradually loading pages, but still under extreme conditions, the system may use more memory to satisfy these queries.
  2. The disks that host Netdata files are extremely slow for the workload required by the database so that data cannot be flushed to disk quickly to free memory. Netdata will automatically spawn more flushing workers in an attempt to parallelize and speed up flushing, but still if the disks cannot write the data quickly enough, they will remain in memory until they are written to disk.
Caches​
DBENGINE stores metric data to disk. To achieve high performance even under severe stress, it uses several layers of caches.
Main Cache​
Stores page data. It is the primary storage of hot and dirty pages (before they are saved to disk), and its clean queue is the LRU cache for speeding up queries.
The entire DBENGINE is designed to use the hot queue size (the currently collected metrics) as the key for sizing all its memory consumption. We call this feature memory ballooning. More collected metrics, bigger main cache and vice versa.
In the equation:
memory in KiB = METRICS x (TIERS - 1) x 4KiB x 2 + 32768 KiB
the part METRICS x (TIERS - 1) x 4KiB is an estimate for the max hot size of the main cache. Tier 0 pages are 4KiB, but tier 1 pages are 2 KiB and tier 2 pages are 384 bytes. So a single metric in 3 tiers uses 4096 + 2048 + 384 = 6528 bytes. The equation estimates 8192 per metric, which includes cache internal structures and leaves some spare.
Then x 2 is the worst case estimate for the dirty queue. If all collected metrics (hot) become available for saving at once, to avoid stopping data collection, all their pages will become dirty and new hot pages will be created instantly. To save memory, when Netdata starts, DBENGINE allocates randomly smaller pages for metrics, to spread their completion evenly across time.
The memory we saved with the above is used to improve the LRU cache. So, although we reserved 32MiB for the LRU, in bigger setups (Netdata Parents) the LRU grows a lot more, within the limits of the equation.
In practice, the main cache sizes itself with hot x 1.5 instead of hot x 2. The reason is that 5% of the main cache is reserved for expanding open cache, 5% for expanding extent cache, and we need Room for the extensive buffers that are allocated in these setups. When the main cache exceeds hot x 1.5 it enters a mode of critical evictions, and aggressively frees pages from the LRU to maintain a healthy memory footprint within its design limits.
Open Cache​
Stores metadata about on disk pages. Not the data itself. Only metadata about the location of the data on disk.
Its primary use is to index information about the open datafile, the one that still accepts new pages. Once that datafile becomes full, all the hot pages of the open cache are indexed in journal v2 files.
The clean queue is an LRU for reducing the journal v2 scans during querying.
Open cache uses memory ballooning too, like the main cache, based on its own hot pages. Open cache hot size is mainly controlled by the size of the open datafile. This is why Netdata keeps datafile sizes bounded and targets many datafiles per tier.
On bigger setups open cache will get a bigger LRU by automatically sizing it (the whole open cache) to 5% to the size of (the whole) main cache.
Extent Cache​
Caches compressed extent data, to avoid reading too repeatedly the same data from disks.
Shared Memory​
Journal v2 indexes are mapped into memory. Netdata attempts to minimize shared memory use by instructing the kernel about the use of these files, or even unmounting them when they are not needed.
The time-ranges of the queries running control the amount of shared memory required.
Metrics Registry​
DBENGINE uses 150 bytes of memory for every metric for which retention is maintained but is not currently being collected.
