Running a Local Dashboard through Cloudflare Tunnels
Summary of tasks
- Make a
netdata-webHTTP tunnel on the parent node, so the web interface can be viewed publicly - Make a
netdata-tcptcp tunnel on the parent node, so it can receive tcp streams from child nodes - Provide access to the
netdata-tcptunnel on the child nodes, so you can send the tcp stream to the parent node - Make sure the parent node uses port
19999for both web and tcp streams - Make sure that the child nodes have
mode = nonein the[web]section of thenetdata.conffile, anddestination = tcp:127.0.0.1:19999in the[stream]section of thestream.conffile
Detailed instructions with commands and service files
Install the
cloudflaredpackage on all your Netdata nodes, follow the repository instructions here -
Login to cloudflare with
sudo cloudflared loginon all your Netdata nodes
Parent node: public web interface and receiving stats from Child nodes
- Create the HTTP tunnel
sudo cloudflared tunnel create netdata-web - Start routing traffic
sudo cloudflared tunnel route dns netdata-web netdata-web.my.domain - Create a service by making a file called
/etc/systemd/system/cf-tun-netdata-web.serviceand input:
[Unit]
Description=cloudflare tunnel netdata-web
After=network-online.target
[Service]
Type=simple
User=root
Group=root
ExecStart=/usr/bin/cloudflared --no-autoupdate tunnel run --url http://localhost:19999 netdata-web
Restart=on-failure
TimeoutStartSec=0
RestartSec=5s
[Install]
WantedBy=multi-user.target
- Create the TCP tunnel
sudo cloudflared tunnel create netdata-tcp - Start routing traffic
sudo cloudflared tunnel route dns netdata-tcp netdata-tcp.my.domain - Create a service by making a file called
/etc/systemd/system/cf-tun-netdata-tcp.serviceand input:
[Unit]
Description=cloudflare tunnel netdata-tcp
[Service]
Type=simple
User=root
Group=root
ExecStart=/usr/bin/cloudflared --no-autoupdate tunnel run --url tcp://localhost:19999 netdata-tcp
Restart=on-failure
TimeoutStartSec=0
RestartSec=5s
[Install]
Child nodes: send stats to the Parent node
/etc/systemd/system/cf-acs-netdata-tcp.serviceand input:
[Unit]
Description=cloudflare access netdata-tcp
[Service]
Type=simple
User=root
Group=root
ExecStart=/usr/bin/cloudflared --no-autoupdate access tcp --url localhost:19999 --tunnel-host netdata-tcp.my.domain
Restart=on-failure
TimeoutStartSec=0
RestartSec=5s
[Install]
You can edit the configuration file using the edit-config script from the Netdata config directory.
- Edit
netdata.confand input:
[web]
mode = none
- Edit
stream.confand input:
[stream]
Restart the Agents, and you are done!
You should now be able to have a Local Dashboard that gets its metrics from Child instances, running through Cloudflare tunnels.
Note
You can find the origin of this page in this discussion in our Discord server.
We thought it was going to be helpful to all users, so we included it in our docs.
