Skip to main content
External plugins
plugins.d is the Netdata internal plugin that collects metrics from external processes, thus allowing Netdata to use external plugins.
Provided External Plugins
pluginlanguageO/Sdescription
apps.pluginClinux, freebsdmonitors the whole process tree on Linux and FreeBSD and breaks down system resource usage by process, user and user group.
charts.d.pluginBASHalla plugin orchestrator for data collection modules written in BASH v4+.
cups.pluginCallmonitors CUPS
ebpf.pluginClinuxmonitors different metrics on environments using kernel internal functions.
go.d.pluginGOallcollects metrics from the system, applications, or third-party APIs.
ioping.pluginCallmeasures disk latency.
freeipmi.pluginClinuxcollects metrics from enterprise hardware sensors, on Linux servers.
nfacct.pluginClinuxcollects netfilter firewall, connection tracker and accounting metrics using libmnl and libnetfilter_acct.
xenstat.pluginClinuxcollects XenServer and XCP-ng metrics using lxenstat.
perf.pluginClinuxcollects CPU performance metrics using performance monitoring units (PMU).
python.d.pluginpythonalla plugin orchestrator for data collection modules written in python v2 or v3 (both are supported).
slabinfo.pluginClinuxcollects kernel internal cache objects (SLAB) metrics.
Plugin orchestrators may also be described as modular plugins. They are modular since they accept custom made modules to be included. Writing modules for these plugins is easier than accessing the native Netdata API directly. You will find modules already available for each orchestrator under the directory of the particular modular plugin (e.g. under python.d.plugin for the python orchestrator). Each of these modular plugins has each own methods for defining modules. Please check the examples and their documentation.
Motivation
This plugin allows Netdata to use external plugins for data collection:
  1. external data collection plugins may be written in any computer language.
  2. external data collection plugins may use O/S capabilities or setuid to run with escalated privileges (compared to the netdata daemon). The communication between the external plugin and Netdata is unidirectional (from the plugin to Netdata), so that Netdata cannot manipulate an external plugin running with escalated privileges.
Operation
Each of the external plugins is expected to run forever. Netdata will start it when it starts and stop it when it exits.
If the external plugin exits or crashes, Netdata will log an error. If the external plugin exits or crashes without pushing metrics to Netdata, Netdata will not start it again.
  • Plugins that exit with any value other than zero, will be disabled. Plugins that exit with zero, will be restarted after some time.
  • Plugins may also be disabled by Netdata if they output things that Netdata does not understand.
The stdout of external plugins is connected to Netdata to receive metrics, with the API defined below.
The stderr of external plugins is connected to Netdata's error.log.
Plugins can create any number of charts with any number of dimensions each. Each chart can have its own characteristics independently of the others generated by the same plugin. For example, one chart may have an update frequency of 1 second, another may have 5 seconds and a third may have 10 seconds.
Configuration
Netdata will supply the environment variables NETDATA_USER_CONFIG_DIR (for user supplied) and NETDATA_STOCK_CONFIG_DIR (for Netdata supplied) configuration files to identify the directory where configuration files are stored. It is up to the plugin to read the configuration it needs.
The netdata.conf section [plugins] section contains a list of all the plugins found at the system where Netdata runs, with a boolean setting to enable them or not.
Example:
[plugins]
# enable running new plugins = yes
# check for new plugins every = 60
# charts.d = yes
# ioping = yes
# python.d = yes
The setting enable running new plugins sets the default behavior for all external plugins. It can be overridden for distinct plugins by modifying the appropriate plugin value configuration to either yes or no.
The setting check for new plugins every sets the interval between scans of the directory /usr/libexec/netdata/plugins.d. New plugins can be added any time, and Netdata will detect them in a timely manner.
For each of the external plugins enabled, another netdata.conf section is created, in the form of [plugin:NAME], where NAME is the name of the external plugin. This section allows controlling the update frequency of the plugin and provide additional command line arguments to it.
For example, for apps.plugin the following section is available:
[plugin:apps]
# update every = 1
# command options =
  • update every controls the granularity of the external plugin.
  • command options allows giving additional command line options to the plugin.
Netdata will provide to the external plugins the environment variable NETDATA_UPDATE_EVERY, in seconds (the default is 1). This is the minimum update frequency for all charts. A plugin that is updating values more frequently than this, is just wasting resources.
Netdata will call the plugin with just one command line parameter: the number of seconds the user requested this plugin to update its data (by default is also 1).
Other than the above, the plugin configuration is up to the plugin.
Keep in mind, that the user may use Netdata configuration to overwrite chart and dimension parameters. This is transparent to the plugin.
Autoconfiguration
Plugins should attempt to autoconfigure themselves when possible.
For example, if your plugin wants to monitor squid, you can search for it on port 3128 or 8080. If any succeeds, you can proceed. If it fails you can output an error (on stderr) saying that you cannot find squid running and giving instructions about the plugin configuration. Then you can stop (exit with non-zero value), so that Netdata will not attempt to start the plugin again.
External Plugins API
Any program that can print a few values to its standard output can become a Netdata external plugin.
Netdata parses lines starting with:
  • CHART - create or update a chart
  • DIMENSION - add or update a dimension to the chart just created
  • VARIABLE - define a variable (to be used in health calculations)
  • CLABEL - add a label to a chart
  • CLABEL_COMMIT - commit added labels to the chart
  • FUNCTION - define a function that can be called later to execute it
  • BEGIN - initialize data collection for a chart
  • SET - set the value of a dimension for the initialized chart
  • END - complete data collection for the initialized chart
  • FLUSH - ignore the last collected values
  • DISABLE - disable this plugin
  • FUNCTION - define functions
  • FUNCTION_PROGRESS - report the progress of a function execution
  • FUNCTION_RESULT_BEGIN - to initiate the transmission of function results
  • FUNCTION_RESULT_END - to end the transmission of function result
  • CONFIG - to define dynamic configuration entities
a single program can produce any number of charts with any number of dimensions each.
Charts can be added any time (not just the beginning).
Netdata may send the following commands to the plugin's stdin:
  • FUNCTION - to call a specific function, with all parameters inline
  • FUNCTION_PAYLOAD - to call a specific function, with a payload of parameters
  • FUNCTION_PAYLOAD_END - to end the payload of parameters
  • FUNCTION_CANCEL - to cancel a running function transaction - no response is required
  • FUNCTION_PROGRESS - to report that a user asked the progress of running function call - no response is required
Command line parameters
The plugin MUST accept just one parameter: the number of seconds it is expected to update the values for its charts. The value passed by Netdata to the plugin is controlled via its configuration file (so there is no need for the plugin to handle this configuration option).
The external plugin can overwrite the update frequency. For example, the server may request per second updates, but the plugin may ignore it and update its charts every 5 seconds.
Environment variables
There are a few environment variables that are set by netdata and are available for the plugin to use.
variabledescription
NETDATA_USER_CONFIG_DIRThe directory where all Netdata-related user configuration should be stored. If the plugin requires custom user configuration, this is the place the user has saved it (normally under /etc/netdata).
NETDATA_STOCK_CONFIG_DIRThe directory where all Netdata -related stock configuration should be stored. If the plugin is shipped with configuration files, this is the place they can be found (normally under /usr/lib/netdata/conf.d).
NETDATA_PLUGINS_DIRThe directory where all Netdata plugins are stored.
NETDATA_USER_PLUGINS_DIRSThe list of directories where custom plugins are stored.
NETDATA_WEB_DIRThe directory where the web files of Netdata are saved.
NETDATA_CACHE_DIRThe directory where the cache files of Netdata are stored. Use this directory if the plugin requires a place to store data. A new directory should be created for the plugin for this purpose, inside this directory.
NETDATA_LOG_DIRThe directory where the log files are stored. By default the stderr output of the plugin will be saved in the error.log file of Netdata.
NETDATA_HOST_PREFIXThis is used in environments where system directories like /sys and /proc have to be accessed at a different path.
NETDATA_DEBUG_FLAGSThis is a number (probably in hex starting with 0x), that enables certain Netdata debugging features. Check [[Tracing Options]] for more information.
NETDATA_UPDATE_EVERYThe minimum number of seconds between chart refreshes. This is like the internal clock of Netdata (it is user configurable, defaulting to 1). There is no meaning for a plugin to update its values more frequently than this number of seconds.
NETDATA_INVOCATION_IDA random UUID in compact form, representing the unique invocation identifier of Netdata. When running under systemd, Netdata uses the INVOCATION_ID set by systemd.
NETDATA_LOG_METHODOne of syslog, journal, stderr or none, indicating the preferred log method of external plugins.
NETDATA_LOG_FORMATOne of journal, logfmt or json, indicating the format of the logs. Plugins can use the Netdata systemd-cat-native command to log always in journal format, and have it automatically converted to the format expected by netdata.
NETDATA_LOG_LEVELOne of emergency, alert, critical, error, warning, notice, info, debug. Plugins are expected to log events with the given priority and the more important ones.
NETDATA_SYSLOG_FACILITYSet only when the NETDATA_LOG_METHOD is syslog. Possible values are auth, authpriv, cron, daemon, ftp, kern, lpr, mail, news, syslog, user, uucp and local0 to local7
NETDATA_ERRORS_THROTTLE_PERIODThe log throttling period in seconds.
NETDATA_ERRORS_PER_PERIODThe allowed number of log events per period.
NETDATA_SYSTEMD_JOURNAL_PATHWhen NETDATA_LOG_METHOD is set to journal, this is the systemd-journald socket path to use.
The output of the plugin
The plugin should output instructions for Netdata to its output (stdout). Since this uses pipes, please make sure you flush stdout after every iteration.
DISABLE
DISABLE will disable this plugin. This will prevent Netdata from restarting the plugin. You can also exit with the value 1 to have the same effect.
HOST_DEFINE
HOST_DEFINE defines a new (or updates an existing) virtual host.
The template is:
HOST_DEFINE machine_guid hostname
where:
  • machine_guid
    uniquely identifies the host, this is what will be needed to add charts to the host.
  • hostname
    is the hostname of the virtual host
HOST_LABEL
HOST_LABEL adds a key-value pair to the virtual host labels. It has to be given between HOST_DEFINE and HOST_DEFINE_END.
The template is:
HOST_LABEL key value
where:
  • key
    uniquely identifies the key of the label
  • value
    is the value associated with this key
There are a few special keys that are used to define the system information of the monitored system:
  • _cloud_provider_type
  • _cloud_instance_type
  • _cloud_instance_region
  • _os_name
  • _os_version
  • _kernel_version
  • _system_cores
  • _system_cpu_freq
  • _system_ram_total
  • _system_disk_space
  • _architecture
  • _virtualization
  • _container
  • _container_detection
  • _virt_detection
  • _is_k8s_node
  • _install_type
  • _prebuilt_arch
  • _prebuilt_dist
HOST_DEFINE_END
HOST_DEFINE_END commits the host information, creating a new host entity, or updating an existing one with the same machine_guid.
HOST
HOST switches data collection between hosts.
The template is:
HOST machine_guid
where:
  • machine_guid
    is the UUID of the host to switch to. After this command, every other command following it is assumed to be associated with this host. Setting machine_guid to localhost switches data collection to the local host.
CHART
CHART defines a new chart.
the template is:
CHART type.id name title units [family [context [charttype [priority [update_every [options [plugin [module]]]]]]]]
where:
  • type.id
    uniquely identifies the chart, this is what will be needed to add values to the chart
    the type part controls the menu the charts will appear in
  • name
    is the name that will be presented to the user instead of id in type.id. This means that only the id part of type.id is changed. When a name has been given, the chart is indexed (and can be referred) as both type.id and type.name. You can set name to '', or null, or (null) to disable it. If a chart with the same name already exists, a serial number is automatically attached to the name to avoid naming collisions.
  • title
    the text above the chart
  • units
    the label of the vertical axis of the chart, all dimensions added to a chart should have the same units of measurement
  • family
    is used to group charts together (for example all eth0 charts should say: eth0), if empty or missing, the id part of type.id will be used
    this controls the sub-menu on the dashboard
  • context
    the context is giving the template of the chart. For example, if multiple charts present the same information for a different family, they should have the same context
    this is used for looking up rendering information for the chart (colors, sizes, informational texts) and also apply alerts to it
  • charttype
    one of line, area, stacked or heatmap, if empty or missing, the line will be used
  • priority
    is the relative priority of the charts as rendered on the web page, lower numbers make the charts appear before the ones with higher numbers, if empty or missing, 1000 will be used
  • update_every
    overwrite the update frequency set by the server, if empty or missing, the user configured value will be used
  • options
    a space separated list of options, enclosed in quotes. The following options are currently supported: obsolete to mark a chart as obsolete (Netdata will hide it and delete it after some time), store_first to make Netdata store the first collected value, assuming there was an invisible previous value set to zero (this is used by statsd charts - if the first data collected value of incremental dimensions is not zero based, unrealistic spikes will appear with this option set) and hidden to perform all operations on a chart, but do not offer it on dashboards (the chart will be send to external databases). CHART options have been added in Netdata v1.7 and the hidden option was added in 1.10.
  • plugin and module
    both are just names that are used to let the user identify the plugin and the module that generated the chart. If plugin is unset or empty, Netdata will automatically set the filename of the plugin that generated the chart. module has not default.
DIMENSION
DIMENSION defines a new dimension for the chart
the template is:
DIMENSION id [name [algorithm [multiplier [divisor [options]]]]]
where:
  • id
    the id of this dimension (it is a text value, not numeric), this will be needed later to add values to the dimension
    We suggest to avoid using . in dimension ids. External databases expect metrics to be . separated and people will get confused if a dimension id contains a dot.
  • name
    the name of the dimension as it will appear at the legend of the chart, if empty or missing the id will be used
  • algorithm
    one of:
    • absolute
      the value is to drawn as-is (interpolated to second boundary), if algorithm is empty, invalid or missing, absolute is used
    • incremental
      the value increases over time, the difference from the last value is presented in the chart, the server interpolates the value and calculates a per second figure
    • percentage-of-absolute-row
      the % of this value compared to the total of all dimensions
    • percentage-of-incremental-row
      the % of this value compared to the incremental total of all dimensions
  • multiplier
    an integer value to multiply the collected value, if empty or missing, 1 is used
  • divisor
    an integer value to divide the collected value, if empty or missing, 1 is used
  • options
    a space separated list of options, enclosed in quotes. Options supported: obsolete to mark a dimension as obsolete (Netdata will delete it after some time) and hidden to make this dimension hidden, it will take part in the calculations but will not be presented in the chart.
VARIABLE
VARIABLE [SCOPE] name = value
VARIABLE defines a variable that can be used in alerts. This is to used for setting constants (like the max connections a server may accept).
Variables support 2 scopes:
  • GLOBAL or HOST to define the variable at the host level.
  • LOCAL or CHART to define the variable at the chart level. Use chart-local variables when the same variable may exist for different charts (i.e. Netdata monitors 2 mysql servers, and you need to set the max_connections each server accepts). Using chart-local variables is the ideal to build alert templates.
The position of the VARIABLE line, sets its default scope (in case you do not specify a scope). So, defining a VARIABLE before any CHART, or between END and BEGIN (outside any chart), sets GLOBAL scope, while defining a VARIABLE just after a CHART or a DIMENSION, or within the BEGIN - END block of a chart, sets LOCAL scope.
These variables can be set and updated at any point.
Variable names should use alphanumeric characters, the . and the _.
The value is floating point (Netdata used long double).
Variables are transferred to upstream Netdata servers (streaming and database replication).
CLABEL
CLABEL name value source
CLABEL defines a label used to organize and identify a chart.
Name and value accept characters according to the following table:
CharacterSymbolLabel NameLabel Value
UTF-8 characterUTF-8_keep
Lower case letter[a-z]keepkeep
Upper case letter[A-Z]keep[a-z]
Digit[0-9]keepkeep
Underscore_keepkeep
Minus-keepkeep
Plus+_keep
Colon:_keep
Semicolon;_:
Equal=_:
Period.keepkeep
Comma,..
Slash/keepkeep
Backslash\//
At@_keep
Space' '_keep
Opening parenthesis(_keep
Closing parenthesis)_keep
Anything else__
The source is an integer field that can have the following values:
  • 1: The value was set automatically.
  • 2: The value was set manually.
  • 4: This is a K8 label.
  • 8: This is a label defined using netdata Agent-Cloud link.
CLABEL_COMMIT
CLABEL_COMMIT indicates that all labels were defined and the chart can be updated.
FUNCTION
The plugin can register functions to Netdata, like this:
FUNCTION [GLOBAL] "name and parameters of the function" timeout "help string for users" "tags" "access" priority version
  • Tags currently recognized are either top or logs (or both, space separated).
  • Access is one of any, member, or admin:
    • any to offer the function to all users of Netdata, even if they are not authenticated.
    • member to offer the function to all authenticated members of Netdata.
    • admin to offer the function only to authenticated administrators.
  • Priority defines the position of the function relative to the other functions (default is 100).
  • Version defines the version of the function (default is 0).
Users can use a function to ask for more information from the collector. Netdata maintains a registry of functions in 2 levels:
  • per node
  • per chart
Both node and chart functions are exactly the same, but chart functions allow Netdata to relate functions with charts and therefore present a context-sensitive menu of functions related to the chart the user is using.
Users can get a list of all the registered functions using the /api/v1/functions endpoint of Netdata and call functions using the /api/v1/function API call of Netdata.
Once a function is called, the plugin will receive at its standard input a command that looks like this:
FUNCTION transaction_id timeout "name and parameters of the function as one quoted parameter" "user permissions value" "source of request"
When the function to be called is to receive a payload of parameters, the call looks like this:
FUNCTION_PAYLOAD transaction_id timeout "name and parameters of the function as one quoted parameter" "user permissions value" "source of request" "content/type"
body of the payload, formatted according to content/type
FUNCTION PAYLOAD END
In this case, Netdata will send:
  • A line starting with FUNCTION_PAYLOAD together with the required metadata for the function, like the transaction id, the function name and its parameters, the timeout and the content type. This line ends with a newline.
  • Then, the payload itself (which may or may not have newlines in it). The payload should be parsed according to the content type parameter.
  • Finally, a line starting with FUNCTION_PAYLOAD_END, so it is expected like \nFUNCTION_PAYLOAD_END\n.
Note 1: The plugins.d protocol allows parameters without single or double quotes if they don't contain spaces. However, the plugin should be able to parse parameters even if they are enclosed in single or double quotes. If the first character of a parameter is a single quote, its last character should also be a single quote too, and similarly for double quotes.
Note 2: Netdata always sends the function and its parameters enclosed in double quotes. If the function command and its parameters contain quotes, they are converted to single quotes.
The plugin is expected to parse and validate name and parameters of the function as one quotes parameter. Netdata allows the user interface to manipulate this string by appending more parameters.
If the plugin rejects the request, it should respond with this:
FUNCTION_RESULT_BEGIN transaction_id 400 application/json
"status": 400,
"error_message": "description of the rejection reasons"
FUNCTION_RESULT_END
If the plugin prepares a response, it should send (via its standard output, together with the collected data, but not interleaved with them):
FUNCTION_RESULT_BEGIN transaction_id http_response_code content_type expiration
Where:
  • transaction_id is the transaction id that Netdata sent for this function execution
  • http_response_code is the http error code Netdata should respond with, 200 is the "ok" response
  • content_type is the content type of the response
  • expiration is the absolute timestamp (number, unix epoch) this response expires
Immediately after this, all text is assumed to be the response content. The content is text and line oriented. The maximum line length accepted is 15kb. Longer lines will be truncated. The type of the context itself depends on the plugin and the UI.
To terminate the message, Netdata seeks a line with just this:
FUNCTION_RESULT_END
This defines the end of the message. FUNCTION_RESULT_END should appear in a line alone, without any other text, so it is wise to add \n before and after it.
After this line, Netdata resumes processing collected metrics from the plugin.
The maximum uncompressed payload size Netdata will accept is 100MB.
Functions cancellation
Netdata is able to detect when a user made an API request, but abandoned it before it was completed. If this happens to an API called for a function served by the plugin, Netdata will generate a FUNCTION_CANCEL request to let the plugin know that it can stop processing the query.
After receiving such a command, the plugin must still send a response for the original function request, to wake up any waiting threads before they timeout. The http response code is not important, since the response will be discarded, however for auditing reasons we suggest to send back a 499 http response code. This is not a standard response code according to the HTTP protocol, but web servers like nginx are using it to indicate that a request was abandoned by a user.
Functions progress
When a request takes too long to be processed, Netdata allows the plugin to report progress to Netdata, which in turn will report progress to the caller.
The plugin can send FUNCTION_PROGRESS like this:
FUNCTION_PROGRESS transaction_id done all
Where:
  • transaction_id is the transaction id of the function request
  • done is an integer value indicating the amount of work done
  • all is an integer value indicating the total amount of work to be done
Netdata supports two kinds of progress:
  • progress as a percentage, which is calculated as done * 100 / all
  • progress without knowing the total amount of work to be done, which is enabled when the plugin reports all as zero.
Functions timeout
All functions calls specify a timeout, at which all the intermediate routing nodes (parents, web server threads) will time out and abort the call.
However, all intermediate routing nodes are configured to extend the timeout when the caller asks for progress. This works like this:
When a progress request is received, if the expected timeout of the request is less than or equal to 10 seconds, the expected timeout is extended by 10 seconds.
Usually, the user interface asks for a progress every second. So, during the last 10 seconds of the timeout, every progress request made shifts the timeout 10 seconds to the future.
To accomplish this, when Netdata receives a progress request by a user, it generates progress requests to the plugin, updating all the intermediate nodes to extend their timeout if necessary.
The plugin will receive progress requests like this:
There is no need to respond to this command. It is only there to let the plugin know that a user is still waiting for the query to finish.
CONFIG
CONFIG commands sent from the plugin to Netdata define dynamic configuration entities. These configurable entities are exposed to the user interface, allowing users to change configuration at runtime.
Dynamically configurations made this way are saved to disk by Netdata and are replayed automatically when Netdata or the plugin restarts.
CONFIG commands look like this:
CONFIG id action ...
Where:
  • id is a unique identifier for the configurable entity. This should by design be unique across Netdata. It should be something like plugin:module:jobs, e.g. go.d:postgresql:jobs:masterdb. This is assumed to be colon-separated with the last part (masterdb in our example), being the one displayed to users when there ano conflicts under the same configuration path.
  • action can be:
    • create, to declare the dynamic configuration entity
    • delete, to delete the dynamic configuration entity - this does not delete user configuration, we if an entity with the same id is created in the future, the saved configuration will be given to it.
    • status, to update the dynamic configuration entity status
IMPORTANT:
The plugin should blindly create, delete and update the status of its dynamic configuration entities, without any special logic applied to it. Netdata needs to be updated of what is actually happening at the plugin. Keep in mind that creating dynamic configuration entities triggers responses from Netdata, depending on its type and status. Re-creating a job, triggers the same responses every time, so make sure you create jobs only when you add jobs.
When the action is create, the following additional parameters are expected:
CONFIG id action status type "path" source_type "source" "supported commands" "view permissions" "edit permissions"
Where:
  • action should be create
  • status can be:
    • accepted, the plugin accepted the configuration, but it is not running yet.
    • running, the plugin accepted and runs the configuration.
    • failed, the plugin tries to run the configuration but it fails.
    • incomplete, the plugin needs additional settings to run this configuration. This is usually used for the cases the plugin discovered a job, but important information is missing for it to work.
    • disabled, the configuration has been disabled by a user.
    • orphan, the configuration is not claimed by any plugin. This is used internally by Netdata to mark the configuration nodes available, for which there is no plugin related to them. Do not use in plugins directly.
  • type can be single, template or job:
    • single is used when the configurable entity is fixed and users should never be able to add or delete it.
    • template is used to define a template based on which users can add multiple configurations, like adding data collection jobs. So, the plugin defines the template of the jobs and users are presented with a [+] button to add such configuration jobs. The plugin can define multiple templates by giving different ids to them.
    • job is used to define a job of a template. The plugin should always add all its jobs, independently of the way they have been discovered. It is important to note the relation between template and job when it comes it the id: The id of the template should be the prefix of the job's id. For example, if the template is go.d:postgresql:jobs, then all its jobs be like go.d:postgresql:jobs:jobname.
  • path is the absolute path of the configurable entity inside the tree of Netdata configurations. Usually, this is should be /collectors.
  • source can be internal, stock, user, discovered or dyncfg:
    • internal is used for configurations that are based on internal code settings
    • stock is used for default configurations
    • discovered is used for dynamic configurations the plugin discovers by its own
    • user is used for user configurations, usually via a configuration file
    • dyncfg is used for configuration received via this dynamic configuration mechanism
  • source should provide more details about the exact source of the configuration, like line@file, or user@ip, etc.
  • supported_commands is a space separated list of the following keywords, enclosed in single or double quotes. These commands are used by the user interface to determine the actions the users can take:
    • schema, to expose the JSON schema for the user interface. This is mandatory for all configurable entities. When schema requests are received, Netdata will first attempt to load the schema from /etc/netdata/schema.d/ and /var/lib/netdata/conf.d/schema.d. For jobs, it will serve the schema of their template. If no schema is found for the required id, the schema request will be forwarded to the plugin, which is expected to send back the relevant schema.
    • get, to expose the current configuration values, according the schema defined. templates cannot support get, since they don't maintain any data.
    • update, to receive configuration updates for this entity. templates cannot support update, since they don't maintain any data.
    • test, like update but only test the configuration and report success or failure.
    • add, to receive job creation commands for templates. Only templates should support this command.
    • remove, to remove a configuration. Only jobs should support this command.
    • enable and disable, to receive user requests to enable and disable this entity. Adding only one of enable or disable to the supported commands, Netdata will add both of them. The plugin should expose these commands on templates only when it wants to receive enable and disable commands for all the jobs of this template.
    • restart, to restart a job.
  • view permissions and edit permissions are bitmaps of the Netdata permission system to control access to the configuration. If set to zero, Netdata will require a signed in user with view and edit permissions to the Netdata's configuration system.
The plugin receives commands as if it had exposed a FUNCTION named config. Netdata formats all these calls like this:
config id command
Where id is the unique id of the configurable entity and command is one of the supported commands the plugin sent to Netdata.
The plugin will receive (for commands: schema, get, remove, enable, disable and restart):
FUNCTION transaction_id timeout "config id command" "user permissions value" "source string"
or (for commands: update, add and test):
FUNCTION_PAYLOAD transaction_id timeout "config id command" "user permissions value" "source string" "content/type"
body of the payload formatted according to content/type
Once received, the plugin should process it and respond accordingly.
Immediately after the plugin adds a configuration entity, if the commands enable and disable are supported by it, Netdata will send either enable or disable for it, based on the last user action, which has been persisted to disk.
Plugin responses follow the same format FUNCTIONS do:
FUNCTION_RESULT_BEGIN transaction_id http_response_code content/type expiration
body of the response formatted according to content/type
FUNCTION_RESULT_END
Successful responses (HTTP response code 200) to schema and get should send back the relevant JSON object. All other responses should have the following response body:
"status" : 404,
"message" : "some text"
The user interface presents the message to users, even when the response is successful (HTTP code 200).
When responding to additions and updates, Netdata uses the following success response codes to derive additional information:
  • 200, responding with 200, means the configuration has been accepted and it is running.
  • 202, responding with 202, means the configuration has been accepted but it is not yet running. A subsequent status action will update it.
  • 298, responding with 298, means the configuration has been accepted but it is disabled for some reason (probably because it matches nothing or the contents are not useful - use the message to provide additional information).
  • 299, responding with 299, means the configuration has been accepted but a restart is required to apply it.
Data collection
data collection is defined as a series of BEGIN -> SET -> END lines
BEGIN type.id [microseconds]
  • type.id
    is the unique identification of the chart (as given in CHART)
  • microseconds
    is the number of microseconds since the last update of the chart. It is optional.
    Under heavy system load, the system may have some latency transferring data from the plugins to Netdata via the pipe. This number improves accuracy significantly, since the plugin is able to calculate the duration between its iterations better than Netdata.
    The first time the plugin is started, no microseconds should be given to Netdata.
SET id = value
  • id
    is the unique identification of the dimension (of the chart just began)
  • value
    is the collected value, only integer values are collected. If you want to push fractional values, multiply this value by 100 or 1000 and set the DIMENSION divider to 1000.
END
END does not take any parameters, it commits the collected values for all dimensions to the chart. If a dimensions was not SET, its value will be empty for this commit.
More SET lines may appear to update all the dimensions of the chart. All of them in one BEGIN -> END block.
All SET lines within a single BEGIN -> END block have to refer to the same chart.
If more charts need to be updated, each chart should have its own BEGIN -> SET -> END block.
If, for any reason, a plugin has issued a BEGIN but wants to cancel it, it can issue a FLUSH. The FLUSH command will instruct Netdata to ignore all the values collected since the last BEGIN command.
If a plugin does not behave properly (outputs invalid lines, or does not follow these guidelines), will be disabled by Netdata.
collected values
Netdata will collect any signed value in the 64bit range: -9.223.372.036.854.775.808 to +9.223.372.036.854.775.807
If a value is not collected, leave it empty, like this:
SET id =
or do not output the line at all.
Modular Plugins
  1. python, use python.d.plugin, there are many examples in the python.d directory
    python is ideal for Netdata plugins. It is a simple, yet powerful way to collect data, it has a very small memory footprint, although it is not the most CPU efficient way to do it.
  2. BASH, use charts.d.plugin, there are many examples in the charts.d directory
    BASH is the simplest scripting language for collecting values. It is the less efficient though in terms of CPU resources. You can use it to collect data quickly, but extensive use of it might use a lot of system resources.
  3. C
    Of course, C is the most efficient way of collecting data. This is why Netdata itself is written in C.
Writing Plugins Properly
There are a few rules for writing plugins properly:
  1. Respect system resources
    Pay special attention to efficiency:
    • Initialize everything once, at the beginning. Initialization is not an expensive operation. Your plugin will most probably be started once and run forever. So, do whatever heavy operation is needed at the beginning, just once.
    • Do the absolutely minimum while iterating to collect values repeatedly.
    • If you need to connect to another server to collect values, avoid re-connects if possible. Connect just once, with keep-alive (for HTTP) enabled and collect values using the same connection.
    • Avoid any CPU or memory heavy operation while collecting data. If you control memory allocation, avoid any memory allocation while iterating to collect values.
    • Avoid running external commands when possible. If you are writing shell scripts avoid especially pipes (each pipe is another fork, a very expensive operation).
  2. The best way to iterate at a constant pace is this pseudo code:
   var update_every = argv[1] * 1000; /* seconds * 1000 = milliseconds */
readConfiguration();
if(!verifyWeCanCollectValues()) {
print("DISABLE");
exit(1);
createCharts(); /* print CHART and DIMENSION statements */
var loops = 0;
var last_run = 0;
var next_run = 0;
var dt_since_last_run = 0;
var now = 0;
while(true) {
/* find the current time in milliseconds */
now = currentTimeStampInMilliseconds();
* find the time of the next loop
* this makes sure we are always aligned
* with the Netdata daemon
next_run = now - (now % update_every) + update_every;
* wait until it is time
* it is important to do it in a loop
* since many wait functions can be interrupted
while( now < next_run ) {
sleepMilliseconds(next_run - now);
/* calculate the time passed since the last run */
if ( loops > 0 )
dt_since_last_run = (now - last_run) * 1000; /* in microseconds */
/* prepare for the next loop */
last_run = now;
loops++;
/* do your magic here to collect values */
collectValues();
/* send the collected data to Netdata */
printValues(dt_since_last_run); /* print BEGIN, SET, END statements */
Using the above procedure, your plugin will be synchronized to start data collection on steps of update_every. There will be no need to keep track of latencies in data collection.
Netdata interpolates values to second boundaries, so even if your plugin is not perfectly aligned it does not matter. Netdata will find out. When your plugin works in increments of update_every, there will be no gaps in the charts due to the possible cumulative micro-delays in data collection. Gaps will only appear if the data collection is really delayed.
  1. If you are not sure of memory leaks, exit every one hour. Netdata will re-start your process.
  2. If possible, try to autodetect if your plugin should be enabled, without any configuration.
