Monitor CockroachDB metrics with Netdata
CockroachDB is an open-source project that brings SQL databases into scalable, disaster-resilient cloud deployments. Thanks to a new CockroachDB collector released in v1.20, you can now monitor any number of CockroachDB databases with maximum granularity using Netdata. Collect more than 50 unique metrics and put them on interactive visualizations designed for better visual anomaly detection.
Netdata itself uses CockroachDB as part of its Netdata Cloud infrastructure, so we're happy to introduce this new collector and help others get started with it straight away.
Let's dive in and walk through the process of monitoring CockroachDB metrics with Netdata.
What's in this guide
Configure the CockroachDB collector
Because all of Netdata's collectors can auto-detect the services they monitor, you shouldn't need to worry about
configuring CockroachDB. Netdata only needs to regularly query the database's _status/vars
page to gather metrics and
display them on the dashboard.
If your CockroachDB instance is accessible through http://localhost:8080/
or http://127.0.0.1:8080
, your setup is
complete. Restart Netdata with sudo systemctl restart netdata
, or the appropriate
method for your system, and refresh your browser. You should see CockroachDB
metrics in your Netdata dashboard!
![CPU utilization charts from a CockroachDB database monitored by Netdata](https://user-images.githubusercontent.com/1153921/73564467-d7e36b00-441c-11ea-9ec9-b5d5ea7277d4.png)
Note: Netdata collects metrics from CockroachDB every 10 seconds, instead of our usual 1 second, because CockroachDB only updates
_status/vars
every 10 seconds. You can't change this setting in CockroachDB.
If you don't see CockroachDB charts, you may need to configure the collector manually.
Manual setup for a local CockroachDB database
To configure Netdata's CockroachDB collector, navigate to your Netdata configuration directory (typically at
/etc/netdata/
) and use edit-config
to initialize and edit your CockroachDB configuration file.
cd /etc/netdata/ # Replace with your Netdata configuration directory, if not /etc/netdata/
./edit-config go.d/cockroachdb.conf
Scroll down to the [JOBS]
section at the bottom of the file. You will see the two default jobs there, which you can
edit, or create a new job with any of the parameters listed above in the file. Both the name
and url
values are
required, and everything else is optional.
For a production cluster, you'll use either an IP address or the system's hostname. Be sure that your remote system allows TCP communication on port 8080, or whichever port you have configured CockroachDB's Admin UI to listen on.
# [ JOBS ]
jobs:
- name: remote
url: http://203.0.113.0:8080/_status/vars
- name: remote_hostname
url: http://cockroachdb.example.com:8080/_status/vars
For a secure cluster, use https
in the url
field instead.
# [ JOBS ]
jobs:
- name: remote
url: https://203.0.113.0:8080/_status/vars
tls_skip_verify: yes # If your certificate is self-signed
url: https://cockroachdb.example.com:8080/_status/vars
You can add as many jobs as you'd like based on how many CockroachDB databases you have—Netdata will create separate
charts for each job. Once you've edited cockroachdb.conf
according to the needs of your infrastructure, restart
Netdata to see your new charts.
![Charts showing a node failure during a simulated test](https://user-images.githubusercontent.com/1153921/73564469-d7e36b00-441c-11ea-8333-02ba0e1c294c.png)
Tweak CockroachDB alerts
This release also includes eight pre-configured alerts for live nodes, such as whether the node is live, storage capacity, issues with replication, and the number of SQL connections/statements. See health.d/cockroachdb.conf on GitHub for details.
You can also edit these files directly with edit-config
./edit-config health.d/cockroachdb.conf # You may need to use `sudo` for write privileges
For more information about editing the defaults or writing new alert entities, see our documentation on configuring health alerts.
